Finally I began my coil spring conversion!!
The third link project is going on, but I found a few problems also there (of course...:doh:).
Firts of all, here there are a couple of pics of what I get from the modification:
The travel is much better than with the radius arms; now is about 12" so it has been doubled.
Let's come to the matters: the upper arm (by the way: 1,25" joint and 1,75" rod, do you think it's heavy enought?) when the passenger side wheel is compressed touches the panhard:
My solution is to make the axle link about 1" taller since I have enough room underneath the engine fan; do you think that the trick could work?
Any other suggestion about the work?
Francesco
Here I am again, this time with some good news and bad news...let's start with the good one!
The car is almost complete: the weldings are done, I've got only the last things to do (rear bumpstops, silencer etc.) but the car is already able to run.
These are some pics from a little test I did in the garden of my house; the first three are about the rear axle; as you can see it has a good ride and I can see that the work came out fine (the ride of the shocks is about 33 cm/13": is 4,5 cm fully compressed and 38 cm fully extended):
And now the bad news: the front axle is quite stationary; the ride of the front shocks is less than 15 cm/6":
I think that the the problem is due to the links of the radius arms: they tie too much the movement.
Now, the solutions could be two:
- the first is to modify these links, maybe putting round uniballs instead of the rubber (uniball like these:
- the second is to change radically the arms system: leave the radius arms but cut away the front bolt and add an arm on the top of the axle, building something like a 3 link.
Now, what do you think about these suggestions? Can you tell me other options (please consider that the whole work is done and I wouldn't change it too much...).
Please help me, once again! :frown::rolleyes:
Francesco
NOW THATS WHAT I HAVE ALWAYS WANTED TO SEE AN FJ DO! theres alot of fj's in lafayette louisiana that have lifts and are very pretty but nothin with that kind of flex!
Ehehe thanx a lot Nick, that's the result of a very hard and long work...and this isn't still finished.
Coming back to my question, I think I can move the 3rd arm link 1,5" upper, so the gap between lower and upper arms would be more or less 10/10,5" (that according to this review 4X4REVIEW.COM: Tech - Toyotal FJ80 Land Cruiser - 3 Link Front Suspension w/ Panhard would be the right quote for 38"/40" wheels running) and there wouldn't be any interference between the 3rd arm and panhard.
Francesco
ok, i almost see the light! :rolleyes:
So, this is the situation now:
The pic has been taken yesterday; as you can see the car is almost finished; but trying the shocks I noticed that the front ones are maybe too tought, specially in compression.
What I ask you is: wich elements influence the hardness? just the nitrogen pression or also the oli level?
What can I do to make the shocks a little bit softer to increase the flexibility, considering that I wouldn't change the car's height that I just set???
Thanks for you help!!! :bounce:
Francesco
Francesco, I have no experience with air shocks specifically, but I have read here that they settle after a while.
With my Motorcycle front ends I have found that too much oil will make the front suspension VERY stiff. I have found that that if I take the end cap off, the spring out and fully compress the shock there should be no oil spilling out. that makes them nice.
Did you add oil to the shocks?
If I under stand you you want to make your suspension softer so it will flex better.
Well the nitrogen in your shocks only give you ride height if you want your front to flex more you will have to 3 link or 4 link it. The 80 control arms will not let you get that kind of flex we have tried every thing and the only way your front will flex like your rear is link the front throw the 80 arms out your wasting your time
I hope this helps
I don’t quit understand what you are looking to change in the characteristics of your shocks?
If they have too much dampening you need to change the weight of the oil to something lighter.
If they are too stiff at the end of the travel of the shock you need to lower the level of the oil. (you don’t want the shock to ever actually bottom out though..)
If they are too stiff at ride height lower shock pressure and raise oil level to keep them from bottoming.
Everything you do to the shocks is tied together so if you change one thing another will change, it will take some tinkering, and I have never tuned shocks on a vehicle, my experience is only with downhill mountain bikes which use all the same components on a smaller scale.
Outback I built a 3link in the front and 4link in the rear, I don't think that the problem are bars and arms.
Thanks to Busta and Pacer, that's exactly what I wanted to know: I just want to gain flexibility without changing the N2 pressure, and basing on your suggestions seems that this is possible just lowering the oil level, isn't it? :idea:
So, the front shocks pressure is now around 180 PSI; taking off some oil I should make the suspenion flex more than they do now without operating on the N2 pressure!
Francesco
Outbakc, I forgot to tell you that the previous pics refer to the old suspension configurations, with the LJ 70's radius arms; now I put a 3link in the front!
By the way, wich is the track bar you're talkin about?
Step by step I'm going to finish my work; yesterday I built the strut bar that was ncessary to make the front suspensions strong enought.
Here it is a pic of the bar (the central bolt needs to set bar's width):
I previously also tried to move a little bit the suspensions, putting out some N2 and this is the result:
Not bad; the car is not high as I wanted but I hope I'll find the right compromise; plus, I still have to set the oil level and this could make me gain a few more centimeters of compression.
Francesco
Your strut looks heavy .. but make little complicated work over the engine and pull out .. ? ( without pull the hole front grill and rad )
From the pic is not clear, but it will be possible to remove the bar; the links will be bolted and not welded (by now I made a few little weldings just to work better while building the bar).
Francesco
Just to let you know, yesterday I went out for the firts test of my air shocked FJ; here there are a few pics:
The firts impression is very good; nothing has broken and everything seems to work fine. The only thing that didn't conviced me is the shocks setting: the work fine in every situation except laterals: they go too much along with the body movements and often the car is near to turn over. I think that this is due to the shocks setting, they probably have to be harder; I'll try different regulations in the future to chose the best one.
Francesco
Do you think so? My fear is to penalize travel too much.
Maybe the problem is the pression of N2 in the shocks, too low; in effect, sunday when I tried the car I wanted to high a little bit the pression but at the end I didn't do it, maybe I should...
Francesco
Francesco
I will try with your air shock pressure rate .. but keep the swap bar option maybe with a quick disconect if you think if it really work at suspension travel limit.
After something like one year and an half year my FJ is finally complete!
The last week I managed to try it in offroad driving and nothing went wrong; it has a great mobility and I need to lock the diffs very rarely.
I still have little problems (like engine or power steering) but they are just ordinary administration...
I would like to thank you for the support and the precious suggestions you gave me during the works sharing a few pics of "the mouse":
Francesco
