This has to be the best thing I have installed yet! So I finally finished up my new fan install last night. Luckily the g/f was away at a work dinner so I had some uninterupted cruiser time to finish it up.
Here is the route I went:
- New stock/heavy duty 4 core radiator from radioator barn - great place to order from btw
-Variable speed fan control unit from SPAL USA - another great company, I had a lot of wiring questions for the cut off switch and David from SPAL was a great help - highly recoomend and their products are high quality and priced well
-Taurus Fan from camcruiser - thanks again!
After figuring out some electrical gremlins I finally got everything working. I installed a three position switch (on-off-on), On-Full Speed, Off, and On-variable speed, also runs if need be when the engine is off. I've also wired in an idiot light for the high-speed override.
The fan control is variable, low speed is set for around 185-190 degrees and high is 205ish. I haven't done a full shakedown on it yet, but I did let the truck idle for 30 minutes or so and it never went above 190, sat around 185ish. What is nice is the control unit is fully water proof, rugged and the wiring is heavy duty. It comes with nice delco style connectors, gives it nice professional install look. I was running a 160 degree t-stat, but I went back to a 180 because of all the stories I've heard about the t-fans cooling so well, I really didn't want to drain and refill the coolant a second time. I also still need to clean up and organzie the wiring so it doesn't look like a rats nest......
