finally bought a Land Cruiser
Very nice find. Looks like it has been loved by it's prior owners and should give you many dependable years. Good luck with the mods!
Nice find! Great color as well.. I am biased.
speaking of maintenance records I took the time to type up all the paperwork I was given to help me plan for future maintenance etc. I'm no expert on this stuff so do you guys have recommendations for anything in the future? The main thing I notice is that the timing belt, water pump etc. was done really early at 62,760 miles. I'm thinking I can go to 162-182k before doing it again based on what Gary at Mudrak told me. Other than heater T's should I do anything else right now? Tires and lift are in the near future.
4/26/17 - took delivery of the Land Cruiser at 143,055 miles
Installed new hood strut
Total dealer service fees - $15,573.59
11/21/16 - 141,278 miles
150k service - engine oil, oil filter, rotated tires from front to rear, topped off fluids, brakes - 8mm front, 5mm rear, tires 5/32 front, 6/32 rear, replaced air filter, performed cooling system fluid exchange, added conditioner, cleaned battery cable ends and installed protector, lubed drive shafts, cleaned throttle body, performed brake fluid exchange, drained and refilled rear differential, drained and refilled front differential, drained and refilled transfer case, added fuel and engine oil conditioner, performed fuel induction service, cleaned MAF sensor, performed crankcase cleaning, performed transmission fluid exchange, added conditioner
$1,392.75
2/19/16 - 136,135 miles
5k interval service - used 5W/30, topped off fluids, tires 6/32 front, 6/32 rear, brakes 7mm front, 7mm rear, rotated tires, cleaned crankcase, added conditioners
$194.65
7/17/15 - 133,260 miles
5k interval service - tested battery - 724CCA, rotated tires front to rear, brake lining front 8mm, rear 7mm, tires 6/32, changed oil, filter, drain plug gasket, topped off all fluids, used 5W30 oil, performed crankcase cleaning service, added fuel and engine additives
$155.48
7/30/14 - 127,420 miles
Perform bi-annual smog inspection
Replaced battery (previous battery failed performance test)
45k interval service - changed engine oil, filter, drain plug gasket, used 5W/30 oil, rotated tires and inspected brake linings, inspected fluid levels, performed battery protection service, installed washer solvent, performed throttle body cleaning service, performed power steering fluid exchange service, drain and refilled transmission fluid, added conditioner, installed oil and fuel system conditioners, tires 8/32 front, 7/32 rear, brakes 8mm front, 7mm rear
$717.23
1/20/14 - 124,808 miles
5k interval service - changed oil and filter using 5W/30, rotated tires, installed washer solvent, retorqued and lubed driveshafts. During service found left C/V boot leaking so replaced boot, replaced left side inner and outer CV boots. During service found lug and stud broken on right rear wheel and replaced.
$642.84
6/22/13 - 120,364 miles
5k interval service - engine oil, filter, gasket, washer solvent, oil/fuel conditioning, compress perf, fuel induction service with mass air flow sensor cleaning (does not include throttle body cleaning), perform air fuel induction service, clean mass air flow and add 44k. During service found noise from front wheel bearings - repack front bearing, found front wheel bearings loose. Removed front wheel bearing, clean and inspected for wear, repacked with grease and installed new grease seals
$920.19
1/19/13 - 117,326 miles
Replaced Drive bulb, 5k service interval - oil, filter, rotate and set tire pressure to 35 psi, topped off fluids
$204.60
8/11/12 - 113,899 miles
Smog check - test failed so replaced fuel cap and retested - ok
$143.36
7/1/12 - 113,103 miles
120k service interval - changed oil and filter, trans fluid, front and rear diff, transfer case, coolant, brake flush, air filter, fuel oil coolant conditioner, spark plugs, rotate and adjust tire pressure, battery service. During service found oil leaking at tube seals. Coil damaged / valve cover and tube seals aged and hardened / replace valve cover gasket and tube seals and coil pack
$1300.22
9/3/11 - 107,887 miles
Found rack and pinion assembly to be leaking from tie rod end seals. Replaced rack assembly with new part, refilled with new power steering fluid, performed wheel alignment, no leaks found after repair
$1426.34
8/28/11 - 107,806 miles
Lube oil and filter service, change oil filter, inspect battery, inspect brakes and perform multi point inspection, topped off fluids and inspected drivetrain for fluid leaks, inspected front and rear brake linings - 10mm front and 10mm rear. Tire tread at 10/32 front and rear. Replaced brake pads this service. Machined rotors:
LF rotor after machining - 30.92mm
RF rotor after machining - 31.04mm
Lubricated hardware and road tested
Removed right CV axle and replaced both axle boots and refilled with new grease and installed new clamps
$755.47
2/21/11 - 105,054 miles
5k service interval - performed oil and filter change, topped fluids, checked lights, lubed hinges, checked belts and hoses for cracks and wear, front brakes - 4mm, rear brakes - 3mm, front and rear tires at 10/32, replaced rear brake pads and machined rotors
$420.08
6/18/10 - 101,601 miles
45k service interval - oil, filter, gasket, battery service, washer solvent, TBI cleaner, ATF conditioner, inj cleaner, replaced transmission fluid. Repack and adjust front wheel bearing.
$1037.33
10/19/09 - 98,792 miles
Oil and filter change with inspection of belts and hoses. Customer reports the VSC and 4x4 light are lit on the dash and the vehicle seems to be stuck in 4WD check and advise - tech confirmed the diff lock activated, tech disconnected the connectors to the diff and reconnected and performed system health check and activated and deactivated the front diff - system ok
Install replacement battery and clean cable ends
Replace wiper inserts
$283.09
1/14/09 - 92,715 miles
Oil and filter, power steering service - fluid exchange, brake fluid exchange
$320.46
8/2/08 - 91,481 miles
Smog
$129.95
4/21/08 - 88,609 miles
30k premium truck service - oil and filter change, replace air filter, fuel induction / decarb service, add oil treatment, perform cooling system fluid exchange, replace transfer case fluid, replace differential fluid, drain and refill ATF, replace PCV valve and clean system, tire rotate and balance, brakes 8mm front and rear, tires 6/32 front and 7/32 rear
$648.96
12/27/07 - 83,759 miles
Change engine oil, oil filter, oil drain plug gasket, rotate tires, inspect brakes top off fluids, checked belts and hoses for wear, lubed driveshaft, hinges and topped off fluids, checked lights, inspected air filter, brakes 7.5mm front, 7mm rear
$71.48
7/12/07 - 78,825 miles
15k premium truck service - oil and filter, tire rotation and balance, drain and fill automatic fuel induction service, add washer solvent and oil treatment, front brakes at 8mm, rear at 6mm, tires at 10/32
$442.44
11/9/06 - 72,740 miles
Install new antenna mast, oil change, top off fluids
$266.63
8/12/06 - 70,506 miles
Smog, 4 wheel alignment, balance all 4 tires
$278.10
7/13/06 - 69,763 miles
Oil change, tire rotation, top off fluids, overall checkup. Brakes 9mm front and rear.
$60.35
1/26/06 - 63,452 miles
Replaced right side tail light
No charge
1/7/06 - 62,760 miles
Engine oil and filter, replaced platinum plugs, Repaired loose bulb socket in rear brake light, replaced timing belt, drive belt, transmission flush service, cooling system power flush, flushed fuel injectors, replaced water pump and thermostat, cleaned throttle body
$1916.17
9/10/05 - 58,799 miles
55k mile service - rotate tires, replace engine oil and filter, install new drain plug gasket, inspect ball joints and dust covers, brake linings, drive shaft boots, air filter, steering linkage. Lube drive shaft and retorque drive shaft and flange bolts, brakes 9mm front, 10mm rear
$103.78
12/20/04 - 49,132 miles
5k mile service - oil, filter, washer solvent, replace rear brake pads, machine rear brake rotors
$182.42
8/7/04 - 45,819 miles
Biennial smog test
$127.25
5/1/04 - 42,591 miles
12mo / 15k service interval - replace engine oil and filter, install new drain plug gasket, drain and refill transmission fluid, top off fluids, service battery, test coolant strength, inspect exterior light, rotate tires, inspect brake linings, replace air filter, brakes 10mm front, 5mm rear, replaced key fob battery
$539.52
11/29/03 - 38,970 miles
4mo / 5k service interval
Oil, filter, gasket, oil supplement, washer solvent, replace front brake pads and machine front rotors
$398.42
Likely missing service records
8/3/02 - 20,671 miles
4mo / 5k service - oil, filter, gasket, washer solvent
$92.73
2/19/02 - 15,953 miles
Customer reports buzzer stays on all the time - tech verified condition, found fuse block shorted, replaced fuse block and rechecked
No charge
12/8/01 - 14,303 miles
12mo / 15k service interval - replaced engine oil and filter, install new drain plug gasket, drain and refill transmission fluid, top off fluids, service battery, test coolant strength, inspect exterior light, rotate tires and inspect brake linings, replace air filter, brakes 10mm rear, 10mm front
$267.43
7/14/01 - 10,457 miles
4mo / 5k service interval - rotate tires, replace engine oil and filter, install new drain plug gasket, inspect ball joints and dust covers, brake linings, drive shaft boots, air filter, steering linkage, lube drive shaft and retorque drive shaft and flange bolts
$92.72
1/25/01 - 5,292 miles
Performed oil, filter change, inspected belts, hoses, and fluid. Rear wiper arm not in correct position - rear wiper arm nut loose - tightened nut to specification
$41.15
$204 for a light bulb and oil change??
I feel bad that the original owner spent nearly $16k on basically routine maintenance, when it shouldn't have been anywhere near that.
However, OP...GREAT FIND MAN!! Enjoy.
What a gem! These are the LCs that every buyers should look for. Owned by elderly, responsible people. I bet this engine has never seen more than 60mph
did the spare tire mod today....much better
