I would like to add the EFI setup. My 83 fj40 is completely stock with emissions, a/c, power steering. Would this setup handle idle up when a/c is running? Are there any go to shops that would do the install? Thanks.
I live at 9700', around town is 7500' and immoften at 5000'....since the Sniper conversion...my rigs drivability is AMAZINGLY better....night + day. Highly recommend!!!x2. I'm planning some high altitude trips this spring and summer and am itching to pull the trigger on one of these Holley or FiTech systems to delete what will surely be days full of tuning, but 1st hand info has been sparse. Whatever info you can provide will be helpful, @Jacob Bridges.
Thanks for all the responses. If I am reading correctly, it is not hard to install yourself? If I still have emissions is that a problem?
at most.I had it done as I'm not very mechanically inclined....we ripped ALL the smog s*** out as I don't have to worry about inspection. Curious as to what my emissions would be post conversion tho and will prlly have it tested just to know. Can't be worse...cannot???Thanks for all the responses. If I am reading correctly, it is not hard to install yourself? If I still have emissions is that a problem?
I do not need emissions for an inspection. However the truck is all original and an 83. I do not have plans to sell currently but you never know. I would like to leave the emissions just in case one day it would go somewhere that require them.
It runs great now but I have all the upgrades it could come with plus some I have added (headlights, radio, etc..) If emissions have to come off not sure I will do it. Thanks for the replies.
True. Depending on their state that may be all that's needed. If a visual is involved then they'd get ding'd for missing equipment.
Sounds like this feature could possibly be used instead of a hand throttle for OBA, winching, etc.From what I can glean from the manuals, the AC kick circuit causes the RPM to temporarily jump by whatever amount you set it to rather than having the ECU catch up after the Compressor kicks on.
