FF Rear Hub Bearings Replace as PM???
TOY350
#1 Super Guy
Grants Pass, OR
Was going to replace my rear hub bearings while doing my gear upgrade and realized that I didn't have to tear down the rear hubs to do my gear swap. Anyone recommend replacing the rear hub bearings at 120K or are these typically good for a lot longer than that? They appear well greased and I have never noticed any sound or vibrations from the rear to make me think a bearing was going out.
Thanks,
Garett
TOY350
Thanks,
Garett
TOY350
Garet, I would replace if needed.. U might as well tear into the rear hub and reaplce the 2 oil seals along with fresh grease.. Inspect the bearings and make sure there are no visable markings/scratches etc... U should be good to go, these bearings last a lot longer than 120k. I tore down my rear hub assembly at about 175k with original bearings and they were flawless...Hope this helps..
If you are that far in, they should certainly be cleaned, inspected and repacked. It would suck to have overlooked something you were only a few steps/minutes away from only to have it fail when you are 500 miles from home.
Thanks for the links Curtis.
I will be replacing them and if the old ones are in good shape I will put them in the new boxes and throw them in tools/parts tub.
I'd completely clean and look to see their condition. I suspect they will be wonderful but you won't really know until you really know! Will only take another approximately 60 minutes to do them. Might as well. If they do indeed look iffy you will need to install the new bearings and the new bearing races; don't just throw the new bearings in there with the old bearing races. HTH. :cheers:
When I did mine rear axle, I cleaned and inspected and saw no issues so I repacked and re-used.
I just rebuilt both axles and replaced all the bearings with Koyo's. When I pulled the old Timken's, they looked great at about 110K. I know that I could have reused them but I feel pretty good knowing there are new ones in there now.
I also highly recommend a bearing/seal installer as opposed to a brass punch/drift.
I have a seal installer and should be able to do it fairly easily. Chances are they are still good but since I replaced all my front bearings I might as well do the rears as well, I will be getting all new bearings on my thirds too.
From the input it seems that repacking is most likely all that is needed but I will replace anyway. Thanks for the input guys.
