Fender Flares
I have 10.5's on mine uncut but 12.5's will not work. I don't think you can clamp flairs so you will have to at least drill...Sorry
I know you don't want to drill, but you can place rubber grommets on the inside and outside of the bolts/nut where you've drilled. Its what I did. I just can see glueing becasue of the mess.
Honestly I could almost feel how split you could be about mounting flares vs destroying a good quarter panel. What I think many others including myself contemplate is the value of your rig. If your so concerned about cutting/drilling the fender then don't modify it. the factory configuration was great for many tire set-ups. Figure your priorities and go for it>
Dude!! Stop doing bong hits before you post!
I can't think of anyway to fasten a flare with a screw or bolt. I body clip might work, but only for a short while; even then you don't have enough body on the fender lip to hold a flare on. Duramex is the only two part epoxy adhesive I would even consider for a load bearing job. even with duramex the bond will only be as strong as the paint is held to the body. Either ditch the wide tires, go with a seriously tall lift or drill the damn things. Just put some paint in the hole first and then use a little permatex in them to keep out the elements.
Keep on smokin' there budddy!
Let someone else mount the flares while you go out to dinner with your wife/girlfriend and when you come home it will be done and you did not have to wittness the drilling, screwing,the cussing, and mutilation of your body work.
33x12.5 = gotta open up those fenders. As for your flares question good luck finding a no-cut no drill flare
x2 - I run this exact tire size and the fenders wells were cut.
Anyway.... the best, cleanest appearing route will be small drill holes with rivets. Most nice fender flares (like those by MAF) come with nice evenly spaced holes already on the flares, you just make nice clean holes in the body and rivet (forget screws) and it looks as good as it gets. Hell, you can even get black rivets so it blends in even more.
^^^Where did you get those rocker guards.. Very nice truck
that is not my rig.... just the one off of Man-A-Fre to show the dude the flares with rivets.. but I have the exact same setup
here are mine...
