I ripped off my rear fender flare (not even off-roading) and would like to reattach it the what remained. Recommendations on what to use? I want to keep them all so not deflaring.
One trick to get the JB weld or epoxy to adhere is to drill some small holes in the meatier remaining portions for the JB weld to fill. I have also used metal strapping and wire to strengthen the bond.
One trick to keep it from happening again is to use zip ties around the retaining studs instead of nuts when you install your flairs. This will keep the flairs attached until you snag them again but may not break your tabs when they come loose.
All of my flairs have some kind of repair holding them on.
Interesting about the FRP. My truck is a 97 and while I'm not certain, I'd swear the material is ABS. Any chance the material was changed at some point? The flare material on the 97 is a very slippery dark colored plastic, no visible fiber to itWell take my word for what you feel it's worth. When I trimmed my rear wheel wells and made new arches to make it look stock again, I had to cut 4 rear flares up and graft them together to make longer rear flares. They've been solid and haven't had an issue in well over a year. The flares are definitely NOT ABS, they are FRP fiber reinforced plastic...basically fiberglass. And there is only one industry recognized way to repair super old fiberglass...EPOXY. clean them up really well...get all your pieces off the rig and use a rough grit sand paper to clean up the mating surfaces... Then clean all mating surfaces again. Get a 2 part Epoxy specifically for plastic and fiberglass...Walmart had it when I did mine. Mix as recommended...don't mix on cardboard or paper, mix on plastic or glass. Epoxy the pieces back together. if you want a really efficient bond, make sure to sand out 2" or so around the breaks and buy some fiberglass cloth at Walmart and some bondo applicators and extra epoxy, cut strips of fiberglass cloth like bandaid size and squeegee mixed epoxy over it until it is saturated then apply some epoxy to the Areas around the break and apply the strips and squeegee them down to add support to the broken Areas. Good luck.
There's always a chance the fender composition was changed...however, very unlikely. If you get a sharp enough separation of material you can see small fibers, also. When I cut mine, it didn't cut like nor smell like ABS, instead of melting like ABS tends to do, it cut pretty cleanly and was powdery and smelled of polyester resin.Interesting about the FRP. My truck is a 97 and while I'm not certain, I'd swear the material is ABS. Any chance the material was changed at some point? The flare material on the 97 is a very slippery dark colored plastic, no visible fiber to it
Mine were not like that in composition, more like either ABS or possibly urethane, not fiber plastic or fiberglass. The improvement of paint adhesion and delamination resistance of paint over more modern plastic makes it quite likely, to me , that the material may have changed.There's always a chance the fender composition was changed...however, very unlikely. If you get a sharp enough separation of material you can see small fibers, also. When I cut mine, it didn't cut like nor smell like ABS, instead of melting like ABS tends to do, it cut pretty cleanly and was powdery and smelled of polyester resin.
X2yep, 93-94 are fiberglass, 95-97 abs plastic.
