Fender Flare Repair
Is the colour molded into the part or is it painted?
Painted I believe. My flares and the ones I used were both white, but when sanded down to fiberglass the grafted area together they were a yellow color on one set and an almost bondo pink on the other, but the backside looked white on both. Not a gel coat from what I could tell
I seriously doubt the later flares are ABS. If they were, they would be easy to repair, as ABS is readily glued with cyanoacrylate, or could be solvent bonded with acetone. The bond with cyanoacrylate can exceed the strength on the base material.
Can these be found at an auto body supply? Id be up for trying it because they are most definitely some type of plastic. Urethane maybe? Whatever it is, jb weld does not work very well
Cyanoacrylate is just the fancy name for Crazy Glue / Super Glue et al. Acetone is available at Home Depot or Lowes.
i keep a cordless drill in the back and some long self tap tek screws and screw em back on before i drive home so they dont fly off on the freeway and use a surfboard repair kit to cover up the screw heads and cracks a quick sand and a coat off elcheapo black paint repair cost is nothing evtime i rip a flare of as i have all this in my shed
Here's my repair:
1947586
