Fan Shroud
Seville, OH
All,
Been calling around looking for a fan shroud. Seems they're a bit tough to locate for a 69 40. Nobody seems to have em. Anybody got one laying around or know where I could find one ?
I may have to have one made if nothing else...
Pretty simple sheet metal project. Braze the joints and paint it flat black.
A guy I saw had cut a rubbermaid garbage can to the length he needed from the top and screwed it to the radiator support. Worked, and it didn't look half bad. very durable.
I think that your original was made from WW2 shell casings gathered up at Okinawa. :)
Put on your cruiserhead hat.
if you can find the fourwheeler issue from a few months ago it shows you how to build one, looked pretty easy. i can look for it if you want its laying around my house some where.
There are two on Ebay right now.
Is your temp gauge working? If you do much driving, 'specially slow in traffic driving, keep your eye glued to that gauge and STOP if it begins to rise well past normal. Don't wait for it to overheat with that pretty new motor at risk. an engine will tend to run a little hot during breakin anyway and if it overheats you could end up with the need for another overhaul or replacement for cracked block or head.
Nobody wants to read THAT thread!
Temp Gauge works fine. It's been running on the cooler side so far. I don't do too much stop and go driving. And it's not a DD. I'll keep an eye on it. I definately don't need any issues at this point with only 500 mles on the new motor.
I've got 2 lines on a new shroud. Should have one by next week sometime.
