fan + power steering belts = problem
Breckenridge, CO
After collecting parts and putting it off for as long as I can remember, I'm finally swapping in the parts for mini truck power steering. But I have a few problems already. I have been researching and don't recall anything coming up.
BTW I'm working on a '71 fj40, f engine, no smog crap...
1. moved the alternator from the drivers side to the passenger side with the 2f alt. bracket. Theres a little bit of rubbing, but I can grind a little bit off the adjustment bracket to make it work. so thats ok
2. I have marksoffroad.net aux. pulley to mount on my single groove harmonic balancer pulley, it included a pair of bolts and a tap, but I already have 2 threaded bolt holes on the existing pulley. Not sure if I should tap those out for the larger bolts included. But I'll call his shop when they open up.
3. After looking at all the pulleys so far, its obvious that the fan is in the way. I figured it would be since I'm adding another pulley. Is there a good way to move the fan out, about 3/4"? Its just the 4 blade fan without a clutch. I guess I could get longer bolts and a load of washers to space it out. But the fan is "hub-centric" to the water pump. Just like your wheels slide on your hubs. So the spaced out bolts seems really ghetto rigged and probably won't have a balanced fan... A machined spacer would be nice, but I don't see that happening. And I really don't need a new water pump, the one on there isn't that old.
I'm just getting started and there are already problems. I am going to take pictures and probably do a write up when I'm done. But I do need everybodys help along the way.
Thanks
:cheers:
Should be able to find an aluminum fan spacer at a better stocked auto parts house....
Should work for that.
Good luck!
-Steve
Is it that easy? That would be awesome! I was looking at it and thinking about flipping the fan around. Looks like it might clear the belts, but still seems a little ghetto to me. Time for a parts run...
Yes, it is that simple. Although, you may find that some auto parts stores handle spacers in 1/2 inch increments. Perhaps you could send the fan forward 1"? Or you could reduce the aluminum spacer by a 1/4 of an inch. Been there, done that in both directions through several mods. Good luck.
I bought the stock spacer from Marv....$5.00 + shipping.
heh,
Ed
