Skillet said:What is thelevel of replacing a fan clutch and updating the thermostat?
Cattledog said:landtank "Todays drive home from The cape was absolutely perfect as far as truck temps are considered.
The ambient temp was 90* and the truck performed great.
Most of the drive the needle was at normal and would only rise slightly on pulling a grade with the TC unlocked. On those occasions where a downshift was needed the needle actually dropped some and the previous situation where I had a temp spike from the upshift at the top of the climb has dissappeared.
As I just tweeked the control plate last time I don't actually know where it is but will post that in a new thread outlining the complete proceedure of what I've done.
At this point I've gone as far aas I can on my own and will need data from other's to refine this for a better across the board ajustment for multiple trucks."
Great to hear! Any idea where I can get the parts local for the temp guage mod? I would be happy to help you get more data on the fan clutch.
BTW, the squeal has come back.....
landtank said:Pete, I think you might be getting ahead of yourself a little. Get the temp gauge modded, that way you can see what temps you're running and then start to diagnose.
A properly maintained stock cooling system should keep up with the heat demands of daily operation. If you need more airflow than what is there then you need to find the problem, adding electric fans is a band-aid.
Cattledog said:Hey Rick,
You also may want to point out that you rig is FULLY armored, supersized power steering cooler, running 35's with 4.88's and has a winch out front. That equipment adds alot of extra mass to pull around.
Pete483 said:That's the thing. The entire block was rebuilt 40k ago. PHH blew pulling a heavy Uhaul over a pass in TN with both heaters on 20k ago. New HG (second one) 10k ago. My fan clutch seems to work in that it spins when it should, but I guess it must not be spinning as fast as it should.
Can I adjust the non-blue OEM clutch? Do I need to buy a new one and then mod it? Different oil?
I've got to move to KY/TN in a month and the last thing I need is my truck overheating out there again. That and I'm losing the hearing in my left ear driving on the freeway with the windows down all the time![]()
landtank said:Yes, but the beauty of this clutch is that it's variable, it only turns on for what the engine needs. So if you have a lighter setup or in cooler weather the clutch simply doesn't come on as strong, this adjustment should work for everyone and have no negative impact on MPG for any given load or ambient temp.
With the older clutch there is no adjustment, the only upgrade option is changing the fluid. If it's not leaking and the bearing is good, check by feeling for play in the fan, then the fluid can be upgraded. I have had good success putting 6000 and 10000 cst in the earlier style clutches on trucks and 4runners.
Can I send my new fan clutch to someone that has done this modification and pay for there time? Truck is overheating way to ofter and I'm tired of running the heater when is summer time. It;s gota be the fan everthing else is new.
Thanks
Rod
