Fan Clutch Fluid
North Carolina
Ok at the risk of sounding like a moron, Im going to ask a question. What the hell is fan clutch fluid, and where do you get it? Please don't respond with use the search engine. Ive done it already for the last six hours. Then I went on a magical quest to find this elusive oil. Closest I got was a hobby shop that said it was diff fluid for R/C trucks. Plain and simple from the gallery of experts now, what is it and where do I get it?
I bought OTA (I think was the brand) from our local hobby store in the 10k flavor. It is used in the R/C rear diffs.
Retro you are a good dude. I thought I was going insane for a while looking for this stuff. Thanks much.
Not finding that brand, but it was something like that.
But here is generally what your looking for.
http://www.amainhobbies.com/index.php/cPath/1_1652_1653/n/RC-Cars-Trucks-Shock-Diff-Oil-Diff-Oil
We have a hobby shop here in town that has it. I just wasn't going to buy it off the word of an R/C tech without confirming with you boys. Im going to pull mine and see if adding some fluid helps. I don't have a roar on start up, and I can spin it freely when its not running. I don't run hot yet though. Just some PM for piece of mind.
Take your time. The bolts are NOT easy (in my case) to remove, I used a small impact cordless drill. Once separated get warm to help (oven is one way, being careful) and setup them up in a drip pan or something in a teepee manner and let drain over night. When re-filling remember to fill both halves.
Most of that is from memory, so I will say to search out the details. I did mine about 2yrs ago, has not been an issue since. We dont have extreme heat or cold here however.
By the way, mine isn't the "blue hub" ive read so much about the last couple days. Was that a 90-94 thing or should they all have it? Mine is not the "blue hub". I know someone said later models were made by Eaton and had black hubs. Sorry for questions but sometimes the threads are pretty vague.
Ok folks, hopefully this thread saves someone time in the future, my comrades offered two types of this fluid already. Here is what I found at my local r/c shop. Factory team silicone diff fluid, manufactured by Lucas oil. 2 oz cost me $ 3.99, I bought two bottles. I hope this helps someone in the future. Oh be prepared for the wide eye stare you get from the r/c guy when you tell him it's going in a real truck.
here is the factory P/N's for the toyota fan clutch fluids
3,000 Cst. = 08816-03001
6,000 Cst. = 08816-06001
10,000 Cst. = 08816-10001
fan clutch fluid toyota p/n's
i opted for the 10k fluid from toyota, i used 2 tubes and i used every bit of it in my black hub fan clutch. The toyota silicone has a yellow tint to it compared to the clear silicone found at hobby shops.
94 Black hub Aisin here just did this Friday. 10k ordered from ebay you'll need ~45ml mine was right at about 47ml. Be careful with the rubber oring in there it will strech on you. I put mine in the freezer for a bit to shrink it up worked out well. gl
Fwiw, I priced the 10,000 cst at my local steelership, $19.65 per bottle. I found the same stuff online at a hobby shop for $3.99 per tube.
Cool I hope this thread actually helped someone besides me. Thanks all for the input.
It helped me.
I have mine out and a 50ml bottle of Mugen Seiki 15k diff fluid from Hobby Town ready. Sloooow draining...
It doesn't look like I'm going to get anywhere near 45ml out of it though.
Thanks!
