Falken at4w in 285/70/18 - anyone got em
Just picked these up. Wildpeak AT4W LT285/70R18 LR-C.
Tundra off road rims, 1.25” spacers. Clears pinch weld *barely* and had to cut a little of the fender liner in front of it.
Initial thoughts are good, just a lot heavier than the P rated Tundra tires they replaced.
View attachment 3553914View attachment 3553915
Interesting. Was looking at this exact combination of wheels / tires. In fact, I purchased a set of the same wheels today and will need new tires by the end of summer. They also look good on a white LC.
I've got KO2s on my LC now. They're 58.6 pounds each. Adding 10 more pounds at each corner, is making me rethink the A/T4W.
Anyone know what the stock 16" OEM wheels weigh. The guy I bought the Tundra alloys from mentioned they are 31 pounds a piece. Anyone know for sure?
@CruisingTheLand Do you think they would fit just fine w/o the spacers?
There are a few threads on here that mention flattening the grease caps on the front hubs and removing some material on the wheel caps to make them fit. But it appears they work fine.
Answered one of my own questions.
Looks like @hoser posted the weights of OEM wheels a long time ago.
So my current OEM setup with the KO2s is 24 + 58.6 = 82.6 pounds on each corner.
Wonder what the Tundra alloys with A/T4Ws are? Any idea @CruisingTheLand?
Didn’t weigh but rims are right around 31 and the YouTubes said the tires weigh in accurately at 68, so looking at 99lbs.
It’s noticeable coming from a 72lb setup, but I’m not 80-series slow or anything.
Update: calculated a full tank and, correcting for size, I’m still hitting around 14.75mpg city
Also put it up on a ramp and I’ll definitely hit pinch weld with the front tire stuffed a little
  • Like
Reactions: LCT
Anyone else with these FalkenWildpeak A/T4WLT285 /70 R18 117S C1 BSW ? Considering buying five of them, as a C-rated tire in this size is appealing to me if it doesn't rub and also fits in the spare location, vs. five BFG KO3s at 275/70/18s that are E-rated. What is not appealing is dropping close to $2,500 on new shoes :oops: :(.
