Headed to Bend on Friday and the Sisters Rodeo.
The rig is ready and the only problem I've created was the seal on the headlight washer tank to the pump is leaking. I'm not sure if it's available still but if that's the only issue, I'd say the frame off experience went well.
Here's a list of some of what I did while the body was off.
- 5spd install
- c channel replacement
- new drive lines from Tom Woods like @Hokie LX
- blasted and coated the frame and a myriad of other parts
- new clutch kit
- machined the flywheel properly
- rear main seal replacement
- galley plug fix
- oil pan gasket
- valve cover gasket
- valve stem seal replacement (completely solved the oil burning and smoke)
- cleaned and replated many of the bolts and hardware
- rebuilt the spare tire winch
- replaced the front bumper and winch (roughly 100lbs weight savings)
- replaced the hitch (roughly 40lbs weight savings)
- new gas tank, sending unit and all the other hoses and clamps including the gaskets and so forth
I started this on March 1st and officially finished it today. Roughly 100 days and completely worth yanking that body... it made nearly everything a million times easier. Thanks for showing me how
@LazarusTaxa !!
My impressions on driving over the past few days with the 5spd. That 1st gear is pretty dang low, which is really nice. The rest of the gears are in a much better range with one another. The trans is still super new so it's a bit notchy but I was told that would subside and I've seen it become smoother in just the past few days. Overall, this one thing has made me fall in love with this vehicle. It makes the rig far more driveable and it just feels like the way it should have been from the factory. Looking at the gearing numbers alone won't give you a proper impression of how much of a difference this makes. If it's possible, the vehicle feels quicker and lighter because of the gearing in that trans.
I have one more really cool addition but it won't be for a couple of weeks. First I need to take Falcor on a road trip. Adventure to come!
Cheers,
Adam
