Failed CA smog test... help
New smog info
OK, here's an update for anyone that might still be following this thread or looking for some answers to their own smog problems.
Here's what I have done so far.
Checked my timing, it was off. Set it to factory spec.
Checked Manifold Vacuum, reading was 18.5mmHg and steady needle.
Gave the mixture screw a 3/4 turn in to lean out the mixture. It was running rich at idle. Used a color tune to check this.
Raised the idle to 850 rpms
Next steps.
Oil and filter change.
New aircleaner
New PCV
Got an email reply from Jim C. Here's what he said about high CO readings
Things to check for high CO readings:
Try a new Toyota air filter.
" " " PCV valve
Make sure timing is set right, maybe even advanced a degree or two.
Make sure vacuum hoses are routed correctly
Check centrifugal & vacuum advance/retard for proper operation.
Engine is burning oil?
Choke is adjusted properly so choke is fully open when driving.
Anyone has any other ideas or suggestions please share them. I will be going in for the retest next week. I'll post my results. Thanks, bob
Bob,
2k miles post recent rebuild. Hmmn... It is not uncommon for the valve lash to need a tweek or two at this point after a rebuild. I'd make that first order of buisiness on a cold motor tomorrow AM. Check head torque while you're at it. I doubt its the carb from what you say. Timing, vacuum and leaky gaskets in that order. Dino oil only, no synthetics for another 7k or so minimum. Put in one of the "high mileage" 20w-50 oils to swell the seals and reduce the oil burning. It will likely go away on its own as the break in continues.
Lou
follow up:
Long Blue passed her emmisions test!!
New plugs, wires, cap, rotor, filter, points, and a carb rebuild.
HC dropped from 2000 to 407 (2500rpm) and 1566.5 to 350 (at idle)
Thanks for the tune up specs Landpimp
drohweder said:
California emmssions is a pile of crap intended to generate money for the state! I had to smog my 76 FJ55 before I sold it. It passed emmision but the dude failed it becuase I did not have a fuel spout regulator on the fill pipe. You know the little thing that keeps you from putting leaded gasoline into your unleaded car? California Sucks!!!!
Bitter Colorado Native
You got hosed because the CA smog nazi was an ignorant SOB. The unleaded restrictor did not appear until catalytic converters were used on Cruisers in around '79.
I bring my OEM smog manual in each time to school them in case they start talking smack about what kind of gear should be found on a '76 Cruiser.
I am pretty sure my 1978 (Sept. '77 pro date) has the unleaded restrictor...
Follow Up.
Passed my emissions test today!!! What a relief.
Thanks to all of you that offered helpful suggestions.
Not sure exactly what made the difference but I'm guessing it was a combination of things.
Here's what i did to pass:
New Toyota air filter
New Plugs
New dist. cap and wires
New rotor
New oil and filter
Set timing to factory spec.
Adjusted carb mixture with vac. gauge.
I didn't pass by much, but I did pass.
Thanks again guys.
Bob
tuolumnejim said:
Thats why I live in a county without smog.
Jim
This is also why a lot of people register there vehicles in county's that don't do smog in CA.
residents should sell this service on ebay :D
manny 72fj40
