RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
Is there already a coating on there they look plated. Theses are straight from Toyota
they only slow you down @RFB80 brakes suck
80 brakes suck
Yes they do, Which is why out of pure frustration, Ive gone new OEm booster to calipers. Theres a set of big brakes in the works but it requires a lot of send out machining and I dont really trust the source anymore. So Im trying it as tho the truck was new. my ABS is gone, my LSPV is gone, just booster SS lines calipers. its got to work. Or Im going hydroboost.80 brakes suck
the hydroboost that acouple guys have swapped to in thier 80s comes with the wilwood, But I dont know S&^% about hydro so I figured ONE more try with all new OEM and now ABS noise in the middle. EBC rotors oem pads calipers and booster has to help. it HAS to.I just went and removed my LSPV and installed a Wildwood Proportioning valve, I also re-routed my front brake lines with a T on the axle housing to eliminate all the extra hard brake lines (much like LCP did) and I have to say my brakes are MUCH better!
I would suggest adding a manual proportioning valve to get your bias correct.
