Fabing a Rear Bumper
Montebello SoCal
First bumper fab for 80 series. will have dual swing outs. better pics to come. Using 3/16" steel plate. Follows the fender flare curves.
This is definately next on my list once I get mt sliders done. Looks great so far, keep us up to date with pictures. Any idea on weight yet? Any plans for a hitch or towing of any sort?
Curt
Curt
Yes it will have a receiver hitch attached. The weight of the bumper is not an issue about 75 lbs. at most.
looks like it is built around the crossmember looks clean so far nice work
looks great!
my only suggestion is to check the clearance at the rear fender/tire. At full compression, you don't want the tire to hit the end of the bumper- it could tear up the tire on that steel.
I'm curious how you are attaching to the frame. Particularly the area of the wings closer to the tire. Are you just using the three threaded holes on the bottom of the frame, or any others. I'd love to see a pic of the underside.
Looks good, I like the angled look.
Will be posting more pics soon. I do have to make sure it wont hit the bumper all parts are reinforced and under construction, besides I have 4 more that I have to build.
Looks really nice. Thanks for the underneath pics.
I have 2 questions/constructive observations: 1-Do the spindles for the swingout just weld directly to the topside of the bumper, or is it a longer shaft that welds to the bottom side as well? (that would be WAY stronger) 2-It looks like the wing is really close to the pinch weld on the bottom of the body. It would be good to leave about 1/2" of space in between. I dropped the back of my truck on a big rock and videoed it just to see how much movement there might be there with the bumper I built. It did move about 1/8" to 1/4" so there needs to be some space there so the body doesn't get tapped on a big hit.
Based on your nice fab work I'm guessing you thought of these things, but I thought I'd ask...
Cheers,
J
Made the swing outs today but cam ran out of bat. will post pics tomorrow, also decided to take the factory bumper off my 62 so that will also be getting a new lexus destroyer (crashed into a shinny new lexus when i built my front winch bumper, no one got hurt)
Cheers,
J
The wings have reinforcement to the frame and there is about 1/4" spacing, the spindles go attached to a plate which is then welded to the bumper it self. The spindle is 1 1/4" solid metal, tested it with 500 lbs. and did not move. so the fab continues.
