F engine ID help
Franktown, CO
I just got a spare F engine. The serial # is F-528108. The numbers cast in to the drivers side rear of the engine are: 11411. The number cast in to the drivers side to the front are 60032 and 40128.
I'm trying to determine if this is a pre 73/74 F motor or if it is a 73/74 vintage F.5? I looked at the serial number info on the SOR website and the S/N would seem to indicate it's a late 73 or early 74 motor. If I use the 40128 number does that mean it was built Jan 28 of 1974?
Can anyone confirm? Thanks
try here
Specter Off-Road, Inc.-Landcruiser Parts & Accessories - Frequently Asked Questions (FAQ's)
Specter Off-Road, Inc.-Landcruiser Parts & Accessories -Engine Serial Numbers
this link shows what the eng number looks like,
looks like your number is missing from these records but if you post up some pics someone will be able to tell if it is an 1F or an F1.5 where's the oil filter located?
74 is the only F engine that had the 2F oiling system. The best way to tell is if you have a spin on oil filter on the passenger's side you have the late F engine. If you have two hoses for the oil filter on the driver's side you don't.
D'oh! Why didn't I think of that?
Yes, it does have the spin on filter on the passenger side, so I guess that makes it an F.5
Thanks
They made F engines in 73 & 74 that were the same cubic inches as the 72 and older F's (239) but they had the 2F style improved oiling system.
more questions than answers
i have a 74 f engine. or at least that is what it was taken out of.
my engine stamp is "f"...see the picture. No numbers.
my oil filter is on the drivers side.
what are the possibilities?
one more thing...
i have rebuilt 5 "f" stamped engines. there were no numbers.
what is this all about????
What do you mean by late, is that newer or older?
AFAIK when you have an engine with no numbers after it ...that means it was a replacement engine. they did not stamp them.
thanks fellow brother...He is risen
JohnnyC, thanks for that bit of data...does that mean my oil filter configuration indicates an older f engine style oil/lubrication system?
to be a 74 F.5 the filter would be the same as a 2f...but...the stamp on the block would say F and not 2F...that would make it a F.5
if you have an F and the earlyer style oil sys...then it is not an F.5 but just a replacement block F155
F.5 filter
F engine oil filter location.
Lucky find on the F.5. It's nice to actually see some oil pressure at idle.
I am looking today at an original 1967 FJ40 with an F motor 235247 serial number. confirmed on the motor numbers also on the paperwork. comments in terms of rebuilding etc?
I am in Colombia and it is better to ship one with original motor also better for restored resale value.
Is the oiling system a problem?
So I have a 71 fj40 I am new to the FJ family Code is on the passenger side oil filter is on the driver side. So is this just a F style engine? Could it be the one that came in that 71?
So I have a 71 fj40 I am new to the FJ family Code is on the passenger side oil filter is on the driver side. So is this just a F style engine? Could it be the one that came in that 71?View attachment 2644644
Yes to both questions.
