Well I'd pull the plugs and give it a big spoonful of Marvel's in each jug. Let it soak for a day or two to free up the rings. Pull it threw 2 revelations to make sure everything is clear. Check the timing and valve lash, prime the oil pump, then pour some gas down it throat and whirl it over and see what happens. If it seems to run good, then cheap new oil and filter plus some carbon/sludge out oil treatment Let it run for the time specified by the oil treatment. Drain the hot crap oil. Put plug in and like 5 gal of diesel and gas and let it soak for a week to 2. Drain that for at least a day. New good oil and filter. Dry/wet compression test and a vacuum reading at idle.
