External VSV mod
NW suburbs of Chicago
Howdy,
Well it's been a few tanks of gas since I mounted my new VSV (the one to the EGR) in an easy-to-reach place, and my P0401 MIL/CEL has remained out, so I'm claiming success.
I'm including some pics in case anyone's curious. To make a long story short, after diagnosing my P0401 awhile ago, I determined the VSV electrical resistance was out of spec, and so the VSV was defective and needed replacing. Being tucked up under the intake manifold/throttle body it is hard to remove, so I decided to leave it there, and mount a new one in an easier spot.
As you see in the pics, the spot I chose is the engine lift bracket. To do this mod, I reached up from under the truck and removed the electrical connector (blue) and vacuum line from the old VSV, and routed them out the front of the manifold. I then re-routed a new vacuum line to the EGR, wire-tying it over the top of the throttle body. The whole job I estimate would take a couple hours (I took a day or so, cuz I farted around trying to figure out what I was going to do).
NOTE that I haven't yet reconnected the EVAP circuit vacuum line (its line is blocked off with a screw in the pictures). Our OBD circuits don't detect any EVAP functionality it seems, and my MIL/CEL light is out, so I plan to tackle it this summer.
Regards,
Kenton
With the right tools, the VSV isn't all that hard to replace :cool:
https://forum.ih8mud.com/80-series-...er-dreaded-401-thread-few-diag-questions.html
Took me 25 minutes from start to finish and it hasn't thrown a code since :)
By the right tools, do you mean something more than Beowulf's original post at IH8MUD.com Forum - View Single Post - Engine Check Light? where he discusses socket extensions? I tried it and didn't work, couldn't get the 2nd bolt off the EGR VSV bracket, even after removing the intake bracket (which wasn't easy itself, getting the lower bolt off). Maybe my hands are too big, and/or being that I'm in the rust belt it could be that everything is just a little too 'welded' on.
I'm impressed with your 15 minute speed-wrenching though-- it takes me about that long just to get my tools together, climb underneath, find out it was a 12mm bolt not 10mm, change sockets, then scoot back out because I decided I needed a light, etc. :)
Regards,
Kenton
Regards,
Kenton
3 long extensions for the rear bolt and a flex head gear wrench for the other :)
To re-install, I used a 1/4 drive gearless ratchet (very small with micro increments)
I actually had a harder time getting the intake bracket off cause the lower bolt was rusted :doh:
I had mine done by a local shop about 4yrs ago and he did that mod. It is kicking code again and it will be easy replacement this time.
I see that you're using generic vacuum hoses. This was the cause of 401 in my case. I recommend using metric hoses for the VSV or pick up couple of oem hoses. I placed my VSV outside as well but now that the CEL is gone, I'll move it back to its original location.
FYI noticed the gas mileage comment on this thread. Its not in spanish.
https://forum.ih8mud.com/80-series-tech/203948-replacement-vsv-spanish.html
It may not be Spanish, but it's not English either. :)
I'm not sure, but I think he said Ali has little girl hands. Ali, you know what they say about men with little (girl) hands! :D
Gosh, that R&R sequence sure does remind me why I made my external mod. His engine looks showroom clean-- mine looks like a greasepit on wheels, with rust and mud and deer**** jammed everywhere. I would cry into Ali's little girl hands if I had to put the VSV back up where I just pulled the old one from.
Thanks for the metric/OEM hose alert Ali. Just another reason to like the external mod, even if it does look STOOPID strapped to the engine hook-- I can change the hoses faster than I can buy them.
Davnic, not sure where you're going with the gas mileage post?
Later,
Kenton
Howdy,
Regards,
Kenton
The VSV opens up and sucks the fuel vapor from the charcoal canister into the intake. So, what's the purpose of plugging up this line? :hhmm:
Good question, Ali. Unfortunately, I have no evidence that the charcoal canister is functional. Do you? The automakers say "it is considered a lifetime" component. I think we both know what that probably means, on a ten-year-old, 100,000+ mile automobile.
If you have any data to the contrary, I would be very pleased to see it, because I would like to confirm/repair my emission system to full operational status.
one guess i have is that if you're not smelling gasoline fumes or excessive gas cap pressure, then the CC is functioning properly.
CC=placebo?
I can confirm from first-hand experience that if you're not smelling gas fumes or excessive gas cap pressure, it does NOT confirm the CC is functioning. (i.e., my CC is not functioning, and I have no fumes or cap pressure).
It would be interesting to see if my experience is typical, but I'm not sure how to do that. I can already see the threads that say "I smelled gas/had cap pressure/saw gas running down my firewall/etc, and I fixed my emissions system, and now it doesn't do that." That doesn't give the full answer on what I'm looking for though-- we also need how many people have a non-functional CC and no issues with vehicle (no smells, no operational difference).
hmm interesting, what was your indication that your CC is malfunctioning?
checking out this one too...VSV replacement coming soon...
status-- dumb repair still working, 2.5 years later
Just an update here. My dum bass external mod VSV still works (no CEL/MIL) 2.5 years and counting, generic vacuum lines and all... (hoping I'm not jinxing it!).
The indication that my CC is not working is that the EVAP circuit vacuum line is plugged. :) No fumes, not sure how to tell excessive cap pressure. When I unscrew it sometimes there is a 'whooshing' sound, is that excessive? heck, it may be time to replace the cap, or at least its gasket. (As well as just about every other gasket and fastener on the lumbering tub of rust).
Lorax
