- Joined
- Dec 28, 2005
- Threads
- 86
- Messages
- 444
You people! Always complicating things!
An AC amplifier amplifies the air conditioner, silly.![]()
Yeah! It makes the cool air cooler
Does my tach have to be functional for my ac clutch to kick in? or does it feed off the distro cap where the tach hooks up to? or is both of these irrelevant.
I looked there and found what looks like a radio button, Looks like the prior owner "jerry rigged it". Turned it either wan and nothing happened.It is under the dash near left knee of passenger seat.
hth
Piggybacking off this thread:
My A/C has started acting differently after I had the head rebuilt. Prior to the rebuild, my engine would jump up about 200 RPM when the A/C was engaged. It seemed to me that this was normal, and I never had any issues with the system.
Now, when I engage the A/C, it places a load on the engine, and drops RPM by about 200 ~ 250 and idles roughly. What should I look at first?
Thanks,
-Hudson
However, that setup looks similar except someone replaced that part with something different.I just realized that I'm asking in the wrong forum... Oops I have a 92 FJ80 3fe!
I noticed that last night from your picture on facebook. Hence the reason you might want to listen to Joey R on facebook as well, he knows 80's best but it could be your onto something with that area too.However, that setup looks similar except someone replaced that part with something different.View attachment 1390094
I know this was a long while ago but I am having the same issue with the VSV idle drops after a minute. Its a brand new VSV. is at perfect High idle when there. Then after the minute no vacuum no power and the AC clutch is on. idle drops below 500RPMHas anyone replaced the A/C amplifier?
Is it available new or rebuilt OEM Toyota?
I have 2 problems:
1. My A/C idle up VSV stops working after the A/C has been on for a minute or 2. I tested the valve itself and it was working fine. When I first turn on the A/C, it always applies vacuum and the idle increases to 900-1000 RPM. After a minute or 2, it kicks off. I think this is related to the A/C amplifier tripping the signal. Adjusting the blue knob doesn't seem to help. Grant here in TX said you could direct wire the VSV from the compressor to correct this problem.
2. Cruising down the highway with A/C running, it will be good and cold and the air blowing well. All of a sudden, the fan will quit blowing or act like it's "frozen up" with only a small amount of air coming out the vents and there will be a lot of really cold condensation down on the ducts. Is this the blower going out, another A/C amplifier problem, or something else?
