exhaust size
washington
I have searched for hours and am not satisfied with my findings. My question is do you think 3" exhaust is to big for a naturally aspirated fzj80. Thanks
In theory if you are going with a single exhaust, 3" should be ok.
A 4.5L pushing around 275HP would be sized between 2.5"-3" for a single exhaust.
I have yet to try this but, wouldn't hesitate to if had the chance.
if after you got it on and thought you had lost some low end you could always add a resenator on the tail pipe to give you a little more back preassure.
Subscribed.
He didn't mention turbo or super charging so your 275HP # is a bit off.
Both my 80's run a 3" exhaust back from the end of the cats and have had no issues. In fact, they run better
Mr. Romer .. which muffler you choose with your 3" exhaust . ? and keep the stock routing ?
Any backpressure loose ..?
I was planning on keeping the stock routing and going with a high flow single cat, and a flowmaster 40 series muffler. I have a stock motor and do not ever plan on a SC or turbo. I just want to make sure I will have enough back pressure so that I do not loose any power. Thanks for all the replies and keep them coming.
I am doing the same thing, and debating the pipe size question. Problem for me, I already bought a 3" in/out cat and muffler. It's a debate to either sell them, and buy 2.5" or just do it. I searched a lot around mud, but no definitive answers.
I am hoping for more replies...
:cheers:
-Josh
:cheers:
-Josh
Oneof my 80's is SC and the other is not (daughters). 3" pipe improved performance on both. In fact I changed out the pipe on my truck before the SC.
I did do it after the cats though. I eventually will replace the cats and go 3" all the way back on both 80's
Cool, thank you...
I'm gunna have the exhaust guy put a Y right after my 02's into my 3" cat, and then all the way back. That sounds best, I have just been hearing debates on 3" pipe being to much and losing flow. the reason I bought 3" to begin with is because TRD uses 3" and all the kits I've seen use 3". I know most of those are for turbo's, but I figured it would be the way to go.
Probably ok, but it's worth hearing some advise about!
-Josh
P.S. I was also thinking about relocating the o2's to the exhaust manifold and ditching the PAIR system since it's a 94' .... But that is wholenother thread.
NLXTACY, thanks for correcting me i think i got the hp/torque figures backwards. i'm still learning... :)
:cheers:
-Josh
If you want to keep your muffler and stay 2.5 the muffler shop has a flare tool that can stretch 2.5 to 3.0 for connecting to cat/muffler.
just a thought.
just a thought.
Actually, that is what me and him talked about doing, but I was reading on here and some other good websites, that it is not good to go up and down in size. The theory is it confuses the gases and the flow of those gases. I guess you want to push everything out in a certain ..... ffooooosh ... ya know :meh: Makes sense to me. I think I will stick with the 3". If it doesn't work, I will gently cut it all out, and sell it on here as a kit or something.
and Thanks for your help ...
-Josh
I have the 3" naturally aspirated and am very happy wth it, but I would not put a Flowmaster 40 series on. I had this muffler on when I first had the 3" done and could not stand the noise so I took it back and had a Magnaflow put on to replace it. It was so frickin loud it was rattling the fillings out of my teeth.:hillbilly:
I got my 95 with a resonator straight pipe instead of a cat and a 40 series flowmaster one inlet two outlet 2.5 in and out. I felt a lil difference in power. Sound is a lil too loud and not deep enough which what i was hopping for can any one suggest a different muffler that may sound more like deep rumble and not so loud maybe a flowmaster 50 or 60?
I have the 3" naturally aspirated and am very happy wth it, but I would not put a Flowmaster 40 series on. I:hillbilly:
the 60 series flowmaster is good. I also used a glass pack to quiet it down, see the links above.
