Exhaust Manifold
Virginia
I'm looking for some advice regarding the exhaust manifold surface that mates to the heat riser/intake.
Do I need to clean up the surface any further(see pictures) or will the gasket compensate for the irregular surface? If so, what should I do to clean up?
I do plan to eliminate the heat riser and use the stainless block off plate.
Thanks for your help!
Jeff
Looks like you never got a response. I'll take a crack at it. I think it's more important that the intake and exhaust surfaces are milled to the same thickness, and the gasket takes care of the unevenness in the mating surface.
However that's a lot of pitting. Hopefully a true expert will correct me.
A little more cleaning with about a 120 grit firm backed disk keeping it as flat as possible, just enough to get the remaining rust and a definite 2nd on the remflex gasket.
