Going in for new exhaust on the weekend and was wondering what others are running. I have the 2 piece header and was thinking a Y pipe off that into a flowmaster or whatever mounted under the driver door with a 3.5" elbow tailpipe sticking out straight sideways. Not excactly legal but it would be pretty rad. Thoughts?
I did something unusual. I first installed a glass back right after the header and it was loud, but a lot more pep. Because I didn't like the loud, I then put in a turbo muffler in series with the Glass Pack. Together, its not loud and gives better performance than the one that was on there before, Looked stock.
when i got my truck it looked like that ... i next out and crushed it on a rock and the fram rail, i had to break it off on the side of the trail and run an open pipe untill i got home cuz the 40 was runing like cra* with exhaust pinched. I will never agin run the exhaust under the fram. I tuck them up nice and out of the way. The only cool thing about open pipe was that ist WAY loud ... but its bad for the exhaust valves
I found a good private exhaust shop in Seattle. Old school place that does custom jobs on hotrods etc. They worked with me and did not mind my hanging around as the tech carefully bent the pipe from the stock header pipe all the way back to the rear. I had them bend all the pipe so that it was all tucked away close to the body between the frame rails. I used 2.5 inch pipe and a flat open Flowmaster muffler. I was glad I was there to "supervise" as we got to discuss each and every bend to ensure that the pipe was protected from possible rock damage as much as possible. I think the old bearded tech kind got into working on the 40: something quite different from his usual routine I guess. The Flowmaster & 2F combo is a little loud but I don't mind it at all. It does sound real loud when I start the rig on very ealry morning weekends prior to a wheeling trip: I am sure my neighbors hate my cruisers. My wife and two dogs can can always hear me returning home from several blocks away...
I was wondering about the exhaust under the frame too, as mine runs under the t-case skid plate with no lift . So I was thinking of trimming the plate a bit and running it just above the plate...it looks like it might need some heat shields, but what do you guys think? sorry to steal the thread...but it's kinda on topic...
I did the MAF headers and bought the 2.5" exhaust from Downey. I like the Exhaust and the muffler is real heavy (has Downey stamped into it) I clamped it into the stock muffler hanger temporary with a big hose clamp, I'll make up a clamp to hold it. The Downey exhaust was made to go to the manifold so I had to chop it a bit and run it to the headers. I routed it above the skid plate.
Max - how hot do your floor panels get? Do you have trouble with grass or brush packng in between the skid plate and being a fire hazard? I know of a place that I think I could con into doing the same type thing you had done, that seems to be the ideal situation.
I need to have some exhaust work done but haven't thought up a good plan on routing with my aux tank under the tub in back. I was thinking of the summit glasspacks or the spintech flatty and dumping the tip out towards the ground right after the skidplate ends at the T-case, but that is potentially a CO deathrap if I ever run a full soft top - not too worried about topless
Anyone have a good routing scheme for side exit without being a rocktrap?
TJ- If I remember, Treeroot did an experiment and figure out that out behind the pass tire is the best. Might double check with him. Top off is a lot easier. I never smell the exhaust in the summer. Its in the winter when the doors and windows are on that it smell sin the cab, but mine goes straight out the back.
My floor panels don't get too hot but then I don't do a ton of long distance driving in the summer. The tail pipe ends behind the pass tire with a slight down curve. I have it end as far as I could without it sticking out. Its a balance between getting rid of the fumes and getiing it smacked on stuff. I really don't get bothered by fumes that much. My problem is that I had to remove the entire heat riser from my manifold. It just rusted apart. Rather than replace the manifold I tapped and screwed in two big bolts where the riser used to go. This turned into a much bigger job than replacing the manifold. I also need to get my carb rebuilt... sigh...
Just got my Downey 4" on and I'm going to have to change the tail pipe around a bit as I flipped the rear spring pack. Pass rear tire is just waiting to nail that tail pipe...
