Excessive oil useage?
KIRKSVILLE, MO
Our 97 LX450 w/ 185K uses about 1 QT oil per 2000 miles. No visible smoking but the idiot light comes on before the next change & the dipstick shows it being low. I will just add some oil & go on my way, till the next scheduled change.
I use Casterol GTX 5x-30 and change the oil & filter every 3-4000 miles.
It is a DD, not offroaded - that is what my Tacoma is for :hillbilly:.
thanks for your input!
Im pretty sure 1qt/1k miles is in the spec for allowable oil usage.
X2 on what D'Animal said.
I only have 165k on mine, but my oil never moves on my dipstick. FWIW, I use Rotella 15W40 and change it roughly every 6000 miles.
I used to run 5W30 and it would consume a quart between changes.
Yeah, I will suggest for you to use a thicker oil. At least a 10W-40. Based on the mileage & lack of blue smoke coming from the tailpipe. I can almost guarantee you that you have an oil leak somewhere. My first two suspects will be your distributor O ring & valve cover gasket. Let us know of your findings.
Same usage
I have the same problem if you can call it that. I run 10W30. My driveway is clean and there is no blue smoke. I just accept it as the way things work.
Yup, hondaguy has it right.
The :princess: truck uses about 1 quart for every 3k miles. Mine uses about 1 quart for every 2k miles. Both trucks get 5w-40 (which is easy to find, finding 10w-40 synthetic is fairly difficult around here for whatever reason).
There are various things you can do, some simple o-rings and seals you can replace. You can make sure all your bolts are snug (such as on the oil pan). That might reduce some oil seepage, but I doubt you'll stop it completely. With your oil usage I wouldn't worry about it, just keep an eye on it and if it starts to get worse, jump on it quick.
Agreed, although, my results tend to vary with driving habits :hhmm:
If I baby her, she won't use a drop all the way up to her 3k interval :) (yes, I'm one of those anal blokes that changes his oil every 3 weeks or less)
If I beat on her, she uses about 1/4 bottle every 1k miles and I think that's far better than average :cool:
Can I have your used oil? :flipoff2:
thanks for the quick replies! :cheers:
FWIW there is no oil under the truck and parked in our garage daily .
I will try a thicker oil 10w-40 (will that be okay in cold weather ie: 0F-40F for the winter) and check the o-ring at the dist.
Overall the engine is pretty clean with no evident oil seepage from fittings or gaskets.
10w-40 should be fine.
If you want to be a bit OC about it, you could put in a block heater or a pan warming pad.
5-30 is the factory-specified weight for a 97 model vehicle. one quart per 2000 miles is not at all excessive. Toyota considers anything less than one quart per 1000 miles to be normal.
It is a very bad habit to wait for the oil light to go on before you check/add oil. Open the hood and check it yourself at least every other fill-up. The oil level light is a crap-shoot at best and a ruined engine at worst.
