Hello, from the 2x2 square tube I will brace directly to the wing of the bumper. Would a web welded in from that brace to the bumper wing add to rigidity with respect to the vertical plane
I added a web similar to yours a few years ago. Like you said, it stiffened the wing but would still flex when hit hard. The web that I welded in caused damage to the body and seams opened up. My build thread has photos of how I cut the body behind the rear wheels in order to give clearance for much stronger bracing.For mine I used a combination of 2" x 2" x 3/16" tube, and 1/4" flat plate. There's about 1/2" clearance minimum between the body and the tube and plate. Using a flat plate the whole way would be easier, but contouring a few tube sections (or in your case C channel open side down might be better) would be stronger but harder. I compromised on mine and used tube at the bottom where the strength is most needed and a flat plate at the top where the shape is more complex and strength is less important. No matter how strong it is it will deflect to some degree when hit, so you gotta leave a reasonable gap in there to keep it from hitting the body.
