I'm about 179-182 per the scangauge in winter and between 181-184 in summer with the exception of a few long hills where I've seen it in the low 190s on very hot days.
This is on a fresh completely overhauled cooling system (all new OEM parts on everything) on a relatively low mileage engine ~100K. I'm pretty convinced that this is the optimum temp that Toyota intended the engine to run at when operating at peak performance.
After seeing the condition of my original factory radiator and the sludge, I'm also convinced that anyone running hotter than normal on an otherwise good condition engine, assuming other parts functioning normally, probably has a partly plugged radiator.
After running this past summer with all new stuff and never having one bit of a problem regardless of condition, I'm convinced that the factory cooling system is more than adequate for almost any situation, temp or load, when in peak condition. That said, I haven't towed anything with my rig so I can't speak to that type of load.
