Engine Removal Adventure
I think that bracket goes on top of the transmission. I can see it on post 95 of my boost thead. Link below.
Stange thing it is near the rear of the tranny. you should not of been doing work there. Maybe there was one near the front too.
Got a broken plug and can't find a replacement. Part number 9098011086
FYI for anyone looking for you via EWD its plug EC1, its for you Center diff lock controls and speedo
I just went digging through as I've torn my harness down this week and was about to mail you one if I had it but.... you broke the one that I cant mail out hahahahah
And that spare bracket bolts on top of the transmission near the tail housing
Well darn.
Thanks on the bracket. This has taken soooo long we find stuff and can't remember where it's from. This has been quite the lesson in what happens when you don't slow and organize your stuff during disassembly.
What's this?...and where does it go?
looks like the ground strap that goes on the rear of the transfer case to the body.
Motor is in and connected. Hood is on. The motor turns over, but does not crank. When we spray started fluid in the intake, the engine tries to crank. We believe we have spark. Checked the fuel pump resistor and fuel pump relay. They both check. Jumpered the fuel pump and have fuel to the fuel filter. No fuel comes out of the fuel return line. So, we the problem has to be from the fuel filter to the furl rail.
Wonder what ever happened to this....???
