Ok. Shot in the dark.Which mileage are you referring to exactly? The overall mileage is just shy of 295K.
I don't see this being a result of the steering gear box. It was replaced with a West Texas Offroad rebuilt unit.
By the way, I did go back with 10W30 dino and the Napa Gold small filter. Engine sounds normal once again. Put it this way: it sounds better. Oil pressure is good, even in hot SoCal and Baja.Interesting. I too recently changed to 15W40 (from 10W30) and installed a Mobil 1 oil filter (which is the large size as compared to the OEM Toyota filter I removed). In park, I too hear a new, slight rattle. I thought it was valve train, it kinda sounds like it's coming from the rear, but lower than the head. I haven't done anything as it's very slight and isn't there when the transmission is engaged. But it was new and enough for me to notice. I suspect the filter, but plan on going back to 10W30 and stock filter next time - which, of course, isn't scientific at all...
Yes, I'm already a big Blackstone guy.Used oil analysis?
If it is something serious (bearings, etc) it should show up even with so few miles on this oil fill. If not, it might take a couple thousand miles.
