Engine oil plug stripped the pan!
raleigh, nc
I’ve only changed oil at Toyota, but they said my ‘99 oil drain plug has stripped in the pan. So they saying to replace the pan $2100 Lol
They said wear and tear, but is this a common problem?
btw it is FRED ANDERSON TOYOTA of Raleigh, I will keep you posted if they right this wrong, Im supposed to speak with service manager tomorrow. They saying 17 hours labor
It is a common problem at dealers I imagine...since they are careless.
Look up a timesert thread repair. It can be fixed for a fraction of the cost of a new pan. Have a trusted mechanic (not the dealer) do it if you are not comfortable.
No it is not a common problem and that should not happen if threaded in correctly and not over torqued. I would demand they fix there problem they created. Drilling and tapping the hole oversize would be the repair I would attempt if I caused the problem.
That's some BS they're calling it "normal wear and tear" lol. I'd likely do the drill/tap to larger size. If they won't do it, you can get an expanding rubber drain plug to hold over temporarily
Looks like they need to learn to use a gasket on the bolt...
ask to see what the hole looks like, is it smooth? or threaded? if threaded it was a helicoil repair that had been done previously
