- Thread starter
- #41
Saturday I ended up getting the old engine pulled and everything swapped over onto my new one like the harness and manifolds.
Sunday morning I started out with swapping out the steering racks.
Now normally if I was going in this deep into a truck I’d replace the radiator as a preventative measure but this one appeared to have a recently installed csf brand radiator with a new set of gates hoses and fancy worm drive clamps on the hoses and trans cooler lines. Now csf wouldn’t be my first choice but I decided to run the radiator but ditch the aftermarket hoses and put some factory hoses and clamps back on. I also made a note to pick up some pcv breather hoses and the two coolant lines at the throttle body. The heater tees I’d replaced when I got it but I do want to do two heater hoses at that spot as well.
