OK, I have posted about this before. The knock I recorded only happens in the morning when the engine is cold. By the time I can get it to anyone to listen to it is gone. Usually, the knock is gone within the first 5 minutes of driving. It slowly tapers off. I have used a screw driver as a stethoscope all over the engine and I cannot find it. I just replaced the water pump and fan clutch hoping that was the problem. Originally, I thought it might be chain slap. The only other thing I can think of doing is replacing the tensioner and maybe checking the oil filter to see if it is gummed up. I have not done that yet. After talking to a Toyo repair tech, he thought it plausible that a partially stuck tensioner could be taking a minute to build up pressure, causing the tensioner to take more time than normal to put the pressure on the chain. At any rate, I know it can't hurt to try that, but I thought I would attach this video to see if anyone has heard this and could possibly tell me what it could be so I can stop hunting and pecking for replacement parts. video
