Engine idling quickly only when warm
Sacramento, CA
I have about 300 miles on my freshly installed (but not rebuilt) engine. It's been running really well, however, I noticed just recently when i pull up to a stop sign it idles rapidly. It wasnt doing this the other day. If I tap the gas a little, it settles back down to a normal idle.
Any ideas on what might be causing this?
Could be an accelerator cable issue. Make sure you have a tiny amount if slack down by the bellcrank. I had mine just a bit too snug and it acted similar.
How's your return spring.
Good idea. I will check the slack. The return spring looks like new.
Could it be a bad PCV valve?
