Engine ID 1973 fj40
Start with the easy stuff. Is it petrol or diesel. Straight six or v8 or 4 cylinder?
The surest way is to find the engine number. Some folk here can eyeball an engine and tell you what year it is.
Got pics?
Got pics?
It's a gas straight 6 distributor on passenger side carb on drivers side
Where would I find the engine #
Between the distributor and starter pretty much
Which side is the oil filter on?
So it has a carb on it now? Why do you need a new one?
That could be due to a lot of things. Might be cheaper to diagnose the problem accurately and fix that problem instead of throwing parts at it and hoping.
Good advise above
I changed the coil , didn't help When it is acting up you can hear the carb sucking air real hard from the drivers seat
I've only owned this a few weeks and this issue just started yesterday
How do I identify what engine is in the vehicle.
Post up a few pics of your engine & serial number.
Engine block serial # is stamped here.
Post up some pics of the carb & engine. I'm in Woodstock and could possibly help if you are near by.
Runs like garbage is a little vague. Do you mean it hesitates or stalls when you hit the accelerator? Does it miss and idle rough?
Acts like vapor lock - does that mean hard start when warm? Or hard to start anytime?
I just went through similar issues with a 72. I bought a carb rebuild kit from Cruiser Outfitters, did a basic tune up (plugs, points, plug wires, rotor, cap, timing) and it ran pretty good afterwards.
It has a weber carb on it and it stalls like it's running out of fuel, you can turn the key off and crank for about 5-10 secs and it will run fine for about 200 yds and then start bucking and lose power and the whole thing repeats itself.
I replaced the coil..no change I replaced the fuel filter and the electric fuel pump and I'm about to try and drive it again.
Should I put a mechanical fuel pump back on it or stay with the electric?
Thanks
Thanks
Ah, now I understand.
Some, well 1 or 2 maybe, run a Weber with great success and can tell you what model you have and how to fix it just right.
Most here, however, if it came with a Weber, would remove it, carry it to the furthest reaches of mapped land and throw it into a large shrubbery. Throwing stones and shouting bad words after it.
Then replace it with the correct Aisin.
