A ~16f difference between Tech Stream ECT and IR gun readings, something wrong!
Was IR gun used engine running or off?
If off, how long after shut down?
Shooting with IR gun is tricky. With engine running, we get air flow effect from fan. Thus lowering (in most cases) reading.
If shot, after engine shut down. Temp increase for awhile. So trick is to take reading, as soon as engine shut down.
IR gun, should also be held within 3" inches.
I like shooting back side of thermostat on water inlet housing. Both engine running and then again after shut down. Engine running, perhaps use a piece of cardboard to block air flow.
It is possible, your ECT sensor reading is wrong. You've two sensors in the 2000. One is for gauge, then other for ECU.
____________________
Fuel trims.
I like monitoring FT, while driving on HWY at ~65 MPH. On flat ground, with no change in throttle position. I monitor ECT, MPH, RPM and FT long and short.
Long term fuel trims. Indicate what ECU is doing to correct. So a reading of say LTFT BK1 7%. Is a lean running condition in BK1. We like to see under 5%. At 5,000 ASL, we see 1-3%. SL (sea level) we may see 0 to 1%.
Many OBD in the markey, form $20 to $100. That connect to smart phone via BT. Most will log moment to moment PID (data) from Tech Stream. These logs, can be down loaded into a Excel. Then by looking at logs MPH & RPM. We can see when holding throttle steady on flat ground, I find most useful.
This screen shot, is before full warm-up and at higher speed than ideal. But you get the idea.
