Hmm? I'll have to check by the compressor to see if I notice any vacuum lines that are missingI think the reason it’s not covered in your emissions manual is because it is a idle up unit for A/C.
It connects to the intake manifold. The factory piece/fitting it attaches to is also a vacuum source for the brake booster. I can see it in your first picture. Follow the larger rubber hose next to the brake fluid reservoir (up and over) to the intake manifold and you will see it.
I'll check it out tomorrowIt connects to the intake manifold. The factory piece/fitting it attaches to is also a vacuum source for the brake booster. I can see it in your first picture. Follow the larger rubber hose next to the brake fluid reservoir (up and over) to the intake manifold and you will see it.
So I think your saying right around here somewhere but I just don't see it?It connects to the intake manifold. The factory piece/fitting it attaches to is also a vacuum source for the brake booster. I can see it in your first picture. Follow the larger rubber hose next to the brake fluid reservoir (up and over) to the intake manifold and you will see it.
Nailed it. The finned vacuum source from the back of the intake manifold doesn't have the AC idle up nipple - that vacuum fitting was for a factory non-AC truck. Good eye Spike. OP could get the correct vac fitting with the AC idle up nipple, or else find another vac source straight off the manifold (probably using a tee).As you discovered, that Idle Up dashpot is for Factory A/C. Not in Emissions FSM. Do you have A/C ? Two things make me think you did not have A/C from the factory: 1- the 'Finned Cooler' in your picture does not have the Vacuum port for the Idle Up Solenoid. That's what was installed at the factory if truck did not have A/C.
2- It looks like you have a York Compressor ?
The function of the Idle Up is to slightly raise the Idle RPMs when A/C is on so truck doesn't lug when moving from a stop with A/C engaged.
yes it has a/c ( not really functioning )As you discovered, that Idle Up dashpot is for Factory A/C. Not in Emissions FSM. Do you have A/C ? Two things make me think you did not have A/C from the factory: 1- the 'Finned Cooler' in your picture does not have the Vacuum port for the Idle Up Solenoid. That's what was installed at the factory if truck did not have A/C.
