I was thinking about the waterproofing issue when I was reading your write up( nice write by the way). You can sleeve the soldering section with shrink tubing and silicon it the rest of the way. That way you can rework it if you have problems later. They even sell the huge shrink tubing that will incase the CCA you put together
Update!:
Went on a long road trip and got to test out the locker - worked great!
One comment - turns out you should indeed do a better job waterproofing the connectors (or use weatherproof connectors). While I still doubt that it'll ever be enough of a problem to engage the motor, I did notice that the indicator lamp malfunctioned a bit when soaked (it was glowing dimly even when unlocked). I'm going to pot the ends of the connectors in epoxy and give the junction a wrap of electrical tape.
