If you have the factory pigtail for the factory switch, the factory pigtail for the factory ECU, and the factory harness that plugs into the elocker then that is all you need.
You need to pull switched power into the ECU. I think the factory uses 20 amps but I think the actual draw is less than 10. You also need to sort the instrument cluster out. Again, if it has the place for the factory diff lock light then I would use that, otherwise order a 12 Volt LED from 12VoltGuy and install it above the switch like I did (although I used 2 LEDs since it was front and rear elockers using an FZJ80 switch).
