Electrical: Why LED bulb doesn't work?
Socal
I am replacing some bulbs w/ LED's. Thanks to Brian4x4's thread, I changed the doors, taillights, and front running lights.
Everything swapped fine except my front marker/turn signal.
It will not light up or flash w/ the LED bulbs. The ARB bumper regular bulbs still flash fine.
It's like there is not enough power for the LED? Regular bulb works fine
Here is how I wired it
IH8MUD.com - View Single Post - Switching front blinkers and marker lights...it works!
I'm sure this is the problem but I don't know how to improve it to get the LED bulbs to work.
Ideas? Thanks all
since the LEDs are a "one way" valve for current to flow the way you have your lights wired now is the problem .
The way its wired the old bulbs allow current to flow both ways and use the other lights for grounding depending one what you are using at that time .
Sorry I cant explain it better but my typing and spelling suck too bad to the point that my spell checker tells me to "F" off with the words I murder in every post :frown:
That makes sense. Thanks guys.
I'll just use regular for now and post up if I figure something out
Try switching the LEDs around. Like someone else said, the built in diode only allows the current to flow one way. You can check for the positive and negative side by using a 9V battery. I think that will solve your problem with getting them to light up but then you may have a problem with the rate of the blink/flash because of the flasher relay. I think speaks to the other comment about the bimetal switch. One of the lighting threads in FAQ has info on a replacement relay that works with LEDs.
Looking at the wiring diagram you posted. If you followed that, it looks like the wrong side of the 'front orange' was grounded.
Most flasher circuits need a certain amount of current to be drawn to operate properly. LEDs do not draw enough current to work properly in most cases. To test put the LED in parallel with a normal bulb on the front.
What SW did with the front bumpers was to a load resistor in parallel to the small bulb they used. I will need to do a few calculations to see what resistor is required, not doing it after a few Jack and Cokes tonight :D
Anyway do the bulb in parallel test first and see what happens, can then figure out a way to fool the system to work wit the fancy LEDs.
BTW, why all the bling on the 80? Seems like you are making it more and more pavement princess these days!!! :flipoff2:
andries,
looking at my diagram:
the "front orange" works with LED
the "side marker" does not work w/ LED.
With incandescent, "side marker" lights up w/ headlights all the time and also flashes w/ "ARB signal"
With LED, "side marker" doesn't light up at all.
Think it's a resistance issue or ground issue?
Does a resistor basically draw more current and convert to heat? In the end, if it is not saving load on the batt or alternator over a regular bulb; I might as well keep it regular.
my pavement princess is still 100% more capable than your built truck :flipoff2:
actually, the LED's are to lessen the power load and boost my drl
Sorry missed your wiring diagram link.
Does G mean ground?? If so the sidemarker should never work as both ends are connected to ground. Seems like the ground on your front orange might be faulty then. So what happens is the front orange and side marker runs in series to the side marker ground. So when you put in a LED it is too restrictive in terms current it allows through and both lights become unfunctional.
Disconnect your sidemarker bulb and see if the front orange bulb works on its own with just normal bulbs. If it doesn't you know the issue is the side marker ground. Then also the sidemarker W/B side needs to be connected to the ARB signal W/B or the front orange pending on which light you want it to work with.
Which light do you want the front orange to work with? Depending the answer the diagram can be redone, just not tonight :D
BTW: Oh yeah, that is why you were too scared to do truck hill after me :flipoff2: LEDs don't help you climb big boy hills :P Hehehehehehehehe. Now shut up and sell your 80 to me, it deserves to be treated worse and not live such a pampered life.
On a more serious note, lets solve that electrical issue once you let me know what you want to work with what.
I think G = green wire, W/B = white/black stripe.
I'm not sure which is + or -
I put the LED in the "sidemarker" and LED in the "front orange".
The "front orange" works fine (w/ reg or LED bulb in "sidemarker").
"sidemarker" doesn't work at all w/ LED. Pop the reg. bulb in and works fine again.
The "arb signal" is a reg. bulb and flashes normally in conjunction with "sidemarker" w/ LED or reg. bulb. (No LED in "arb signal").
Don't know if it matters but the "sidemarker" LED is a 1156 dual contact. It lights up all the time & flashes w/ turn signal.
Hope that's clear
*I want the "side marker" and "front orange" to light up when I turn on the lights.
and "side marker" and "arb signal" to flash when I signal a turn.
(this is how it works currently with regular bulbs in the sidemarker and LED in the "front orange")
So the "side marker" is a dual function. the other two are single function.
hmmm...didn't see you in the tank trap either! :p
Your diagram only shows 2 wires going to the side marker. There should be 3 wires if it's a dual function bulb.
attachment.php
Can you look again and tell us how it's currently wired. I'd agree that if "G" means ground, that LED will not work since it's connected to 2 ground circuits.
Hmmmm, OK. This is now like looking at half a puzzle without the OEM wiring diagram to see what and where the G and W/B goes.
So everything is fine with a normal bulb in the side marker, but goes fubar with an LED in it.
The 1156 is listed as single contact casings, is the bulb single or dual contact, cause the LED # you listed is supposed to be single contact. Probably need to clarify that.
From what I understand from above the side marker does not light up at all now, not with the front orange or the ARB signal???? All other lights still work fine in their single function. If that is the case try switching the wires on the side marker, so G on SM goes to G of Front Orange, W/B on SM goes to G on ARB.
The outside casing of bulbs typically goes to ground or - (however many vehicles are ground switched - so you can't just test it with everything off). Does the G on the front orange go to the metal outside casing, same question on the ARB signal? Trying to reverse engineer the vehicle wiring diagram.
