After reading many threads I have partially isolated what I beleive to be short and could use some advice on the next step.
A little history, after not driving the cruiser for 1 week I go to start and no battery. I had a problem about 4 months ago with a aftermarket starter and replaced it along with a new battery. I charged the battery overnight to a healthy 13.7 V and install. Upon install I notice a small spark so I do some research. Initially I thought that having the brake contoller, clock, ecu and a phone charger plugged in may have drained it down. I go to check the current in series and set the meter to 400 mA setting after reading what others are drawing while the iginitition is off 20-30 mA. Needless to say I blow a fuse in the meter use a spare and check with the 10 A seeting and get a reading of 4.6 A.
I start checking current across each fuse in the interior fuse panel rather than pulling each one separately and find that the #2 Fuse "Tail" is pulling over 300 mA with the iginiton off, lights off, brake controller unplugged, and phone charger removed. Only one other has a reading the #10 for the ECU about at 20 mA which seems normal. This appears to point to a short in the #2 circuit. It was getting late, so I disconnected the battery for more research.
1.So what is next, were do I go now and what should I look for and check?
2. I did have a bad connection at the rear hatch behind the door hatch panel to the the wiper moter that was fixed. Could this still be related to this circuit?
3. Is there any common item I should check for this circuit that has givin any others a problem.
guy like myself.
