I have some electrical issues that are keeping me from my maiden vogage (around the block...)
First,
I have some gauge issues, and I have searched the forum. I have a '79 Pig, and the Temp, Fuel, and Amp gauges used to work, and they stopped all at the same time. The Oil Pressure gauge still works, and the heater blower works independently of the gauges which should be on the same fuse.
Does anyone know how the gauges are grounded? I know to check the ground (White w/ black stripe from the electrical diagram), and it looks like there are 3 or 4 of them coming out of the gauge cluster connector to a wiring bundle. Do you know where they go from there? Maybe these are ground wires coming in from the sensors? Does the cluster itself ground to the dash or? I've definitely got myself in a cluster, allright! If I can avoid tearing into that wiring bundle, that would be great. I don't want to take it out on the first trip without a temp gauge.
Second,
I think I have the popular fuel solenoid problem, but all of the posts say to connect the one yellow wire to +12V. I have TWO wires coming out, black and white with a black stripe. I figure the white one is ground. I tried attaching +12V to the black one and get no clicking. Also, I put the voltmeter on the wires coming from the dash and get no voltage w/ the key in the "on" position. Any suggestions (should I replace the solenoid then rewire to switched power??
3'rd,
What is this electrical component in the pic? It is attached to the left fender well, and the wires that go to it are cut.
I've been pushing to get my project out on the road before it gets too cold (chopped top), but I think it's too late!
Many Thanks in advance,
Chuck
First,
Second,
3'rd,
Chuck
