Electrical issues...
Jackson, ms
Anyone who can help...thanks in advance. I have been struggling with this for a while now.
i recently replaced my taillights on my 75 FJ40. I had to cut off the plastic connectors for the lights' plug in becuase the old ones were too corroded to deal with. So I have had to individually wire each light. My old blinkers worked fine they were just old and rotted out.
Now I can't get my blinkers to work properly. They only blink when I rev the engine. When idling or without the engine on they click once and just stay on.
Some friends in the Cottonland cruisers have pointed me in the direction of a ground problem. So after doing some reading i took a new wire and ran it from the negative battery terminal to the blinker wire connection behind the taillight.
When this ground is in place the blinker makes the blinking "click click" sound but the light goes out and stays out until i disconnect the ground!
Also, since i have put in these lights my fuel guage and my temp guage have quit working. could there be any connection between these two problems?
Any ideas for a solution to any of these problems?:confused: ?
Need a bit more information. You replaced the light housing with the same thing just in better shape right? Exactly which wire did you connect this ground from the battery to? You should connect it to the light housing to ensure it is grounded properly. Once you have that connected then you can trouble shoot a bit further. Next step would be to remove the blinker bulb and measure the voltage at the blinker light socket at idle. It should be maybe a volt or two below battery voltage depending upon the state your wiring and connections are in. Also clean the contact on the bulb, it could be corroded. Try that and lets us know!
Take a wire brush to your fuse panel. Afer removing the fuses. This solved a similar problem for me in my 76 FJ40.
I bought entire new lights on ebay. Housing, cover, etc. Brand new just not oem...
I connected the ground directly to the bridge that connects the positive wire of the brinker light. So basically it is three wires coming together: the ground, the wire coming out of the blinker itself, and the positive wire coming out of the harness.
How would i connect it to the housing? To one of its mounting bolts? Should i solder it on there? I tried just touching the ground to the housing just for a test and nothing happened. That is why i tried the wire.
I don't have any way to measure voltage, but i will clean things up in the sockets and the fuse box and see what happens.
Thanks
You're stroking yourself without a multimeter. The housings should ground through their mountings. With a multimeter you can test the ground continuity and wire brush as necessary.
You shouldn't have to solder a secondary ground wire to anything, lest you become what we refer to as a PO.
The reason that the lights don't blink at idle is because they aren't sinking enough currect to trip the mechanical flasher.
The reasons that they don't sink enough current include a bad connection anywhere between the battery and ground or an improper, low wattage bulb.
If you don't want to fool with it, you can just get an electronic flasher and it will blink no matter what.
I don't really uderstand where you connected the ground wire, but on most lights, the metal lamp housing is the ground and not a wire.
hwgates said:
I connected the ground directly to the bridge that connects the positive wire of the brinker light. So basically it is three wires coming together: the ground, the wire coming out of the blinker itself, and the positive wire coming out of the harness. Thanks
Sounds like you connected ground to the positive which should have blown a fuse or at best kept it from blinking.
Thanks
Solder a wire to the reflector housing, put a male bullet connector on the end, put a female bullet connector on another section of wire, plug them together and run it with the other turn signal wires to the fender well. Put a ring connector on the end and put the ring under a bolt on the fender for a good ground. This gives you an easy way to remove the lights AND have an ground that's not dependant on the turn signal to fender connection for a ground.
You can get a $5 test light at any automotove place that will allow you to do some basic troubleshooting. We can help you learn to use it. Basiclly you clip the test clip to a good ground then use the probe end to find wires that are hot ( have +12V on them).
Make sure you have a full charge on your battery.
Check your Car Grounds are in good shape. You should have the following:
Battery to Engine Block
Engine Block to Frame
Small wire off of Battery to Body (fender bolt)
The blinkers ground through the housing and to the body. The internals on the front blinkers could be shot. If you recently painted you could have paint in the threads.
thanks for all the input, i have been out of town this weekend but will get to looking at it tonight. I found a multimeter so I will be testing all the wires.
I connected the ground wire to the positive wire for the blinker. i know The metal housing should ground itself . I had a similiar problem with my front blinkers not grounding b/c they were loose. I got new bases for those front blinkers and now they are grounded fine.
All this is making me worried that since these taillights are not OEM that they are not going to be compatable. I'll give an update on my work later.
Thanks
You don't want to do this, since it creates a short circuit. Electric power needs to make a complete path or circuit from one post of the battery to the light and from the light to the other battery post and by grounding the power wire you are creating a short cut for the power that bypasses the light that you want to run, cutting it off from power. I'm surprised it didn't blow a fuse. The fact that a fuse didn't blow may be an indication that you have a bad connection upstream (toward the battery + post) of where you connected the ground.
good deal... I didn't think it would be the right spot, i just started trying anything when touching it to the housing didn't work.
It tells you the ground isn't the problem. Since you didn't blow the fuse, chances are that you have a bad connection somewhere upstream that cause the voltage at the bulb to be too low. Start following the wire back toward the battery with a test light or a volt meter until you find the place where the voltage (or test light bulb brightness) jumps up. Use the color code and a schematic to track the wire connection points. The bad connection is between the last two test points when the voltage jumps up. They are generally bad spade lug connections and not broken wires, so test those points first. A broken wire is hard to find and it is easier to just run a new wire.
The blinkers have started to work properly to some extent. I think that aside from probably some bad wiring, it was a low charge on my battery. It keeps doing better the more I drive so that leads me to believe this is the case. BTW I have not added any ground wires so i think the original grounding is fine.
Although i still have one issue. When I hit my brakes the front side lights come on. Some of the lights in the blinker housing to be precise.
Also my reverse lights are working now! So I think I have the wiring to the back blinkers 98% right. Just not sure.
bad connection
sounds like a bad connection/ short between two wires ratling arround when driving.keep driving it;driving is either going to help it or make it worse.
