What is the most logical approach for tracking down a problem with my carb cooling fan? The fan hasn't worked since I got the truck over 6 years ago.
I have pulled the fan out and hooked it directly to the battery and it turns on with no problem. What else should I check?
Also, turn signals don't work but hazards do. When I turn the blinker on, it blinks once and stops. Would this be the turn signal relay or a bad ground? How do you check the relay?
