I had this problem about a year ago, cleaned the battery terminals and it went away until now. . .
For some background, I have a '96 LX 450 with about 165000 miles. I've been driving it without a battery hold down as it didn't have one when I bought it. I wedged some oil bottles in the battery tray to keep the battery from moving and all had been fine (I do have a hold down with the J bolts and nuts currently on order with my local dealer).
My 80 won't start. I guess I should say won't start consistently. At times it will just click, others, it clicks and goes dead. Sometimes it will start and then it will start 3-4 times fine, then it won't again. When I loosen the bracket from the battery terminal and move it around, I get sparks and I can hear the power to the relay(?) click on and off. All the lights come on in the cab and it seems I have power, I turn the key and I get a click, or a click and all the lights disappear (everything goes dead).
I'm pretty sure I have a short somewhere but where should I start? Should I just replace the fusible links? Are there any simple tests I can perform to isolate the problem? I am very electronically challenged and don't have a voltmeter or any other electrical tools besides wire cutters. Before I take it somewhere and pay more than I should, I wanted to get some feedback here.
idea (the more white trash you are the more genius it is). I had a s**** piece of MDF sitting around from a recent house project and decided to put that in the bottom of the tray to boost the battery up a bit. I could tell that the battery should be sitting higher because the wires angled down to connect to the battery. This 3/4" boost did 2 things for me:
