Electric window issue
santa cruz
ok so. I recently bought this 91 FJ80 and the driver’s side window when it goes up bangs at the top. Like it doesn’t know to stop? Not seeing limit switch or something like that. There are some wires soldered on that I haven’t traced through under the dash yet, help me LC wizards
There is no limit switch on any of the windows. You let go of the switch when the window is closed. No 80 Series came with "auto up" on any window, but there is a modification for that.
Not understanding the "banging at the top".
Is the rubber window run torn?
Is the window not running properly in the track?
Have you inspected the window track?
When the other windows reach the the top, they stop, the drivers window doesn’t, need really good timing to stop at the precise moment. Rubber is ok. Any clues on what the soldered on leads might be for?
Your explanation might make sense to you, but you're just going to confuse most of us: The motors on ALL the windows run until you let go of the switch; even when the window's all the way up.
Hey Wait: Are you saying there's a ratcheting sound once the driver's window closes??
This should be a link to a video of the issue
Figured it out. Didn’t want to take everything apart before maybe having an idea for a fix. Missing some teeth. Put back together and will see about a replacement.
