Don't you need something along the lines of a 100amp Alternator?
I know SPAL reccomends that on their 16 fan you 30amp relays and on their new high performance 16 inch fan you run a 60amp relay.
WHen you test drove the truck an it hit 220, where both fans going at full speed? and could you feel good airflow coming across the radiator?
I have a 16 inch SPAL fan that I'm goin tto have a friend fab up an aluminum radiator shroud for and plan to try that out this summer and see what happens. I'm concerned about the clearance between the radiator and the water pump, becuase its fairly close. If I recall its something less than 5 inches between the water pump pulley and the radiator core?
Unless you run some kind of aftermarket high AMP alternator I just don't think you're going to have enough amps to power the fans correctly. I think you'll find that most cars / trucks that have OEM electric fans run 100+ amp alternators....
