EGR Tube Delete
Will Van
GOLD Star
Austin, TX
I'm in the middle of a PHH and FHH replacement.
How do I access the EGR tube to delete it? Through the front wheel-well while I'm doing the PHH?
**** that noise!!! Haha!
Should I really pull the head? I know Toyota had head gasket issues because of banning asbestos in these years. You really think I should pull the head and swap head gaskets?
Throttle back buddy.... no need to pull the head yet. I'm sure there's a way to get that pipe off.
Yup! Just drop in a blockoff plate between the riser tube and the upper intake. No more gas movement means no more heat spice. Remove the plumbing when/if you pull the head.
I just made my own block off plates. I pulled the front tire and the fender flaps and unbolted the pipe. It was TIGHT fit but not too bad. I unbolted the pipe from the top and the other EGR accessories and pulled out everything from the top. As others have stated, loop the vac lines on the intake manifold. Although the EGR pipe is further back, my hands were significantly more sore doing the PHH.
My block off plates are made of 3/16" steel. I reused the gaskets just to be sure there were no leaks.
I forgot to provide a follow-up update. I was able to remove the EGR pipe through the DS fender. I had the upper intake manifold off too.
A buddy made a block off plate for me after I lost my Wit’s End keychain on top of the trans bell housing. For the second round, I tied one of the eyelets to a string until I got the other eyelet bolt started (This ensured if I dropped it again I could fish it out). Then I cut the string and added the second bolt. Works well and no hot exhaust gas running by the wiring harness.
Replaced the PHH and deleted the TB coolant line while I was in there.
ive been looking into doing this but havnt really looked in depth yet. is there just the one port in the back of the engine thet you block or is there more?
There are two ports to block. One at the back of the head (pictured above), and one on the intake manifold. Plus, you'll need to trick the ECU for the EGR temp circuit, otherwise you'll get a CEL. On the OBD1 truck you just have to create a jumper on the temp sensor pigtail. On OBD2 you need a resistor in the jumper.
@Will Van when will this thing be back on the road? You've had it torn apart for a while now!
I know! The project continues to get bigger with the more "while-you're-in-there" type stuff. Plus, the Ron Davis radiator had the incorrect fittings for the transmission cooler lines. So I had to send it back and get some other stuff changed when they warrantied it.
I just replaced ALL this EGR stuff I had no idea I could yank it. its expensive for OEM
Yup toss it all , I’ve been egr, pair, vsv, catsand vacuum line free for couple years, the only thing I regret is the cats will be adding one back in
Also tossed abs, and cruise control, adds little room on both sides
