I have a HJ60. It has been acting up lately. When driving you can hear a relay click from passenger footwell. After that a small stuttering on engine. I assumed it is fuel control relay. I opened it up. It was quite rusty inside. I cleaned it as good as I could. Went for a test drive. It worked fine. Then after a few days studdering came back. I got my hands on a new fuel control relay. With that the fuel enrichment is allways on and the smoke is heavy. I have tried 4 used fcr. Last one is fully working. But it did nothing to my studdering. I also tried to disconnect the oil pressure sensor for EDIC. Did not help. Lastly I changed the EDIC to a other used one. This helped. Went for a 20km test drive and to my friend. It worked like it should no problem. Then we went for a little drive with my friend and all good. When leaving home the whole way it stuttered. It was approx. 6-8sec between stuttering and relay clicking. So for a few kilometers every 6 seconds it stuttered. With EDIC rod to pump disconnected everything is fine.
What can I do next? The car worked fine for almost three summer. Last autumn it started act up.. Please someone help...
