easy fix?
Conejo valley
Driving down the freeway both of the shifters rattle like crazy. The shifter for the four wheel drive used to be the only rattle that I had and I did the quality fix with the bungee. Now the other is rattling as well:frown:. Any thoughts on how to fix this, or is it something that requires me to pull the trany?
I dunno, it's been a while since I had a Toyota transmission....BUT, if you pull the cap that holds the stick in the the top of the tranny, you see that spring that used to have grease on it between the cap and the tranny. What would happen if you renewed that grease? Sure would be easy, if it worked. Just a thought.
As for the transfer case stick rattle, again, it's been a long time. I have 3 sticks there now and they all rattle. Bungee still works for those.
Pulled from another thread:
"Get underneath and tighten & grease your transfer case Lever linkage. You'll be able to lose the "anti rattle" cord!"
Good luck.....
