early wiper motors
Seattle, WA
My wiper motors are kind of slow and I was wondering if anyone has ever rebuilt these things or if its even worth it. How fast are these motors supposed to work? I was thinking about taking them to a eletrical shop and seeing what they think and how much. Thanks a lot
I've rebuilt four of them so far. None of them were working. broken wires, frozen shafts. All working now, the TNK is a very good wiper motor. I know of a four wheel drive shop that use to sell them for use in early jeeps. I would replace the brushes, sand the shaft, clean the gears and grease. Well worth repairing IMO.
John
beleive it or not, toyota still stocks the early motors, I recall $50 each, they are slightly different then the orignials however, but I understand they do fit(I think Chef got a pair not long ago)
Now you may ask why Toyota still has wiper motors in stock for a 40 year old fj40?.........well because they were used thru at least the mid 70's(maybe into the 80's) in other markets....as they were used with the split front windows on non US 40's :)
Well, it seems the auto electrician guy cant work on them. He says I should just buy new ones if I don't like how these ones work. So I guess I am going to have to dig into them myself and see what i can clean/break. :D Hey John(living in the past), where do you get the brushes for them.Are they a pain to change? Thanks
They're pretty siimple inside, as these things go. Just do it on a tray so nothing rolls away, keep your digital camera handy to snap before pix, and line it all up or draw pix as you take it apart. Only use electronics cleaners if you're cleaning the armature or around the field coils - other solvents (like acetone) can dissolve the laquer insulation on windings, which leads to smoke and destruction upon start up.
You can polish the commutator with a pencil eraser. The brushes are pretty garden variety, and if they need replacement, you can get something close from the motor shop, a power tool service shop or appliance repair and sand or file them to size. It's kind of fun to roll back the clock to a time when it wasn't all throw away. Clean the gears and shafts, lube them back up with some lithium grease, button it up and away you go! Be really careful on bench testing them, because the parking relay shorts across two of the terminals - don't ask me how I know . . . something about hurrying to finish at 11:30 after a couple of beers . . . .
Oh, and only do one at a time, just in case you get inturrupted, you'll have a guide to reassemble
Good luck!
I just bought one this week.. Pimp that was me not chef.. And Just picked up my second one to match the first one this week.. Brand new, the only difference is they are upside down and the motor will mount about a half-inch higher and they park backwards from the originals.. Thus why I purchased a second one to match..
The orginal ones came two ways. The earlier ones the motors was lower, showed thru windshield from the outside, later ones the motor mounted higher. wires came from the left side on both type at least on the LHD vehicles. On my 25 I plan on using earlier type because the PO installed a rollcage that doesn't leave room for the second type. The crossbar just barely clears the vacuum wipers.
John
I get you two mixxed up....sorry :)
park backwards.....makes sense, they are prolly for a RHD
Chase, if it turns out you need some small parts for inside the motor, I have one on the shelf that had the shaft break on it but still looks good inside. I can throw it in a box and send it to you with whatever you order from me next time.
I knew there was a reason I kept that. ;)
